Question about M-Audio Studio Pro 3 Professional Desktop Audio Monitors Retail Speaker
I plugged my StudioPro 3 speakers into a 220 outlet and switched them on before changing the voltage setting on the rear of the left speaker. How can I have it repaired locally. I'm in Vietnam........Ho Chi Minh City......thanks............I know.....this was just dumb
    Problem Solver:
  • 13 Answers
Ouch! You likely killed the transformer - and hopefully that's all. You will need to replace this with an equivalent rating ie: 240 ac volt primary, 18-24vac secondary.
These are OEM for M-Audio and difficult to get through M-Audio ...an exact match from the original manufacturer is not possible but you can get close from other resources.
Posted on Oct 31, 2009
  • 832 Answers
I"m sure you can find an electrical or electronic service
shop in your city. Take it to them and have it repaired.
Posted on Sep 24, 2009
Standby mode
When the STANDBY indicator
flashes
Immediately unplug the power cord
and check the following items.
• If your unit have a voltage selector,
is the voltage selector set to the
correct voltage?
Check the voltage for your region,
then make sure the voltage selector
is set correctly.
• Are the + and - speaker cords shortcircuited?
• Are you using the supplied
speakers?
• Is anything blocking the ventilation
holes on the rear of the unit?
After checking the above items and
fixing any problems, plug in the power
cord again and turn on the unit. If the
STANDBY indicator still flashes, or if
the cause of the problem cannot be
found even after checking all the
above items, consult your dealer.
Dec 20, 2012 | Sony Mhc-gn1300d 3 Dvd/vcd/cd Changer...
Hi....I need a wiring diagram for the stock amp in my grand am gt...its a 2003
Monsoon System Pinouts
Pin Wire Color Function
E1 LT GRN Right Front Speaker Output (+)
E2 TAN Left Front Speaker Output (+)
E3 GRY Left Front Speaker Output (-)
E4 LT BLU Right Rear Speaker Output (-)
E5 DK BLU Right Rear Speaker Output (+)
E6 BRN Left Rear Speaker Output (+)
E7 YEL Left Rear Speaker Output (-)
E8 BLK Ground
E9 BLK Ground
E10 DK GRN Antenna Relay Coil Supply Voltage
E11 ORN Battery Positive Voltage
E13 BLK Left Front Tweeter Speaker Output (+)
E14 YEL Left Front Tweeter Speaker Output (-)
E15 DK BLU Left Front Midrange Speaker Output (+)
E16 LT BLU Left Front Midrange Speaker Output (-)
F1 DK GRN Right Front Speaker Output (-)
F2 LT GRN Right Front Speaker Tweeter Output (+)
F3 PPL Right Front Speaker Tweeter Output (-)
F4 PPL Left Rear Tweeter Speaker Output (-)
F5 RED Left Rear Tweeter Speaker Output (+)
F6 DK GRN Right Front Midrange Speaker Output (-)
F7 ORN Right Front Midrange Speaker Output (+)
F8 PPL Gain Control Signal
F9 -- Not Used
F10 YEL Right Rear Tweeter Speaker Output (-)
F11 WHT Right Rear Tweeter Speaker Output (+)
F12 -- Not Used
F13 LT BLU/BLK Right Subwoofer Speaker Output (-)
F14 DK GRN Right Subwoofer Speaker Output (+)
F15 DK BLU/WHT Left Subwoofer Speaker Outlet (+)
F16 LT GRN/BLK Left Subwoofer Speaker Outlet (-)
or it is here 3rd one down
http://www.grandamgt.com/forum/forumdisplay.php?f=76
May 08, 2011 | Audio Players & Recorders
Hi with regards to my audio a7x monitor speaker... on the unit it says 2 options 220-240V 50hz 100-120V 60hz IT says use only with a 250v plug.. which i did:/ the speaker just doesnt turn on at all?...
You must switch the voltage option to match the mains voltage in your area.
If you have 220 or 240 AC volts mains voltage in your area and you have set the switch on your monitor speaker to 100-120 volts and then connect it to the mains supply then you have destroyed your speaker.
Mar 14, 2011 | Audio Players & Recorders
Where do I get a volume control switch for a M-Audio studiopro 3?
@ Radioshack PN 271-0002 Volume Control with Push Switch, it will fix the speakers but make them MONO, so you need 2 of them to make it stereo. I recommend 2 cause this speakers have the volume distribution problem from factory.
Jan 02, 2011 | M-Audio Studio Pro 3 Professional Desktop...
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
Where can I find replacement parts for these speakers?
Your best bet is to replace them for $79
http://pro-audio.musiciansfriend.com/product/MAudio-StudioPro-3-Professional-Desktop-Audio-Monitors?sku=603709&src=3WFRWXX&ZYXSEM=0&CAWELAID=26047440
Otherwise you are limited to being able to replace with the same size but not the same part. In other words, no one makes exact replacement parts for those.
Mar 14, 2010 | M-Audio StudioPro 3 Computer Speakers
Will my Logitech X-230 speakers work in a country with 220-240 V power outlets or would i need an adapter to use them there? If i connect them directly to the 240 V outlet, will they run properly or would...
Check the back of your sub to check your voltage range. You will see something like this: 110V-120V or 110V-220V. If you see the later, you are ready to go. If you see 110-120V only, you will need a power converter to power your speakers as well as any other 110-120V equipment. But no matter what, if it is 110-120V DO NOT PLUG DIRECT TO 220V!! It will blow your speakers. (I lived in Germany for 11 years.)
Aug 12, 2009 | Logitech Z-2300 Computer Speakers
How do i hook this up Samsung HT-WX70 Theater System with Wireless Speakers
1. Connect the front left, front right, center, and sub woofer speakers to the back of the home theater system.
2.
With the home theater system off, insert the TX card into the TX Card connection (WIRELESS) on the back of the home theater.
Important:
Make sure to insert the TX card with the slanted portion of the card facing left.
3. C
onnect the rear left and the rear right speakers to the back of the SWA-3000.
4.
Plug the power cord of the SWA-3000 into an electrical wall outlet, and then switch the power switch on the back of the SWA-3000 to [ON]
Hope this helps!
Jun 27, 2009 | Samsung HT-WX70 Theater System
Logitech x-530 rear speakers and Center speaker not working
you have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
Dec 02, 2008 | Logitech X-530 Computer Speakers
M-Audio Studio Pro 3 Professional Desktop Audio Monitors Retail Speaker Logo
278 people viewed this question
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
SHIVAJI YADAV
SHIVAJI YADAV
Carlos L. Burgos
Carlos L. Burgos
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
