Where can I find drivers for my modem dir-301? I can´t come out on Internet!
    President:
  • 1,901 Answers
Routers do not really have drivers per se. They ahve firmware. Have you tried setting it up as instructed in a manual? Below is a link to a DIR-300 which has basic setup procedures. There should be a resessed Reset button in the rear of the router to restore it to factory settings. Installation begins on Page 8. if using DSL or Cable, start on page 11. Run the configuration which begins on Page 14 (Not 16).
ftp://ftp.dlink.co.uk/dir_products/dir-300/DIR-300_Manual_v2.00.pdf
I have looked all over the world for a DIR-301 and cannot find one. What country are you in?
Here are some additional DIR-300 downloads:
http://www.dlink.com.au/tech/Download/download.aspx?product=DIR-300&revision=REV_A&filetype=Firmware
Posted on Sep 24, 2009
I purchased a D-Link Wireless N 150 Router, Dir 600L. I am unable to setup the same. Do I need a Modem also to setup this router or I can setup without a modem?
You can setup a wireless network without a modem. It will allow you to share printers, files ect. The modem is required for an internet connection only. The modem basically translates the Ethernet traffic in to a signal that can be carried over your respective service, DSL over a POTS line or broadband over a coax cable. The word modem stands for MOdularDEModular note the word MODEM in there.
Dec 24, 2012 | D-Link DIR-600 Router
D-Link DIR 600 connection problems
If this is the case, there is no problem with the router. the problem is with the modem.MAke sure that the cable from the modem goes into the WAN(Internet) port of the router.And also, what kind of internet are you using? is your router set up properly to work with your provider?
Is there any problems when you connect your pc to the modem directly with the cable, or does the problem occur only in the wifi connection?
Feb 18, 2012 | D-Link DIR-600 Router
Solid yellow Internet light on D-Link DIR-825
Try a new working LAN cable between your internet modem and the router. Is your internet modem connected and working? You should be able to directly connect using a LAN cable to check the modem connection. Reboot your modem and router.
Nov 16, 2011 | D-Link DIR-615 Wireless Router
I have a DIR-600 router to connect my Cable modem and use wireless connection to connect to the internet. It was all working fine till my modem LAN port got damaged somehow.I have changed the modem and now...
Try following this order before you connect your computer to the router.
power off all your equipment (cable modem & router & your computer's wireless card)
first, power on the cable modem, give it some time to boot up and get an IP from the ISP, say 30 secs.
then, power on the router, again, give it some time to boot and obtain its internet IP from the cable modem
finally, enable wireless on you computer and connect to the router.
if this doesn't solve the problem try resetting the router to factory defaults by pressing the reset button at its back for about 10 seconds with the router powered on.
This your router's manual it may turn handy:
http://global.dlink.com.sg/site_support/DIR-600/Manual/DIR-600_B1_Manual_v2.pdf
good luck
Jun 12, 2011 | D-Link DIR-600 Router
My ISP gave me a USB modem(Wanadoo ADSL) which i connect my telephone line and a USB to connect the modem to my pc.I bought a D-link DIR-825.Do i connect the telephone line directly to the DIR-825 or i...
Plug the modem filter in the wall, plug the modem into the filter, then plug the router into the modem. From there you should be able to set up your network or personal internet.
Mar 12, 2011 | D-Link DIR-825 Wireless QuadBand Router
I need a driver for my dlink dir-300
you dont need a driver to use this router just plugged in your modem to your DIR300 then open internet explorer or any browser then type this on the address bar
192.168.0.1
enter user name <admin> and leave the password blank if you havent changed the username and password
Aug 29, 2010 | D-Link DIR-300 Wireless Router
CAN NOT GET INTERNET FROM DIR-655 TO NS7000S
Are you trying to set up the router. You can do it manually without the CD. Make sure that your computer is able to go online through the modem. If your computer is not able to go online through the modem then you will need to call ISP first. If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP.
Apr 05, 2010 | D-Link Xtreme N DIR-655 Wireless Router
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
DIR-615 will not connect to internet. Followed step by step... doesnt recognize the internet connection... but I can wire in to the connection.
hii, i had the same problem, if you have a gateway (modem) you can join them together and turn the modem on and wait for it to finish starting then turn your dir-615 on, and you shouldnt even have to configure it, it should just work, it did for me.
Jul 17, 2009 | D-Link DIR-625 (790069292637) Wireless...
I have Shaw as my provider and have bought a new HP. I bought the DIR-615. I connected according to the instruction but had no internet when connected. I call your tech and he could not help me. He said I...
Gil try to turn off the modem and router for 5 minutes then plug it back in modem first before the router. Obtain the IP address of the computer if you have any? Check the Internet connection after that? your Internet service provider is cable right?
Mar 10, 2009 | D-Link DIR-625 (790069292637) Wireless...
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
