Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
Installing D-Link bridge for my TV
I have a Panasonic TV with viera cast for internet connection with an ethernet plug. I have a DAP-1522 D-Link Xtreme N DUO wireless Bridge/Acess Point. Also I am using a D-LInk DIR-600 wireless 150 router. I can not get access to http://DLINKAP for the setup wizard, it says link is broken. I pinged the router and it ws fine, but when I pinged the bridge it failed. I tried setting the bridge up by the quick setup guide but no luck yet. I have way too many hours involved for such a simple task. One article said he hooked the bridge up to his wired PC, I don't understand how he did it because there is only one ethernet plug on my PC and its for the modem. Pretty well lost. Any help greatly appreciated.
  • b_climie Sep 24, 2009
    How can I change IP address for the router to match TV?
  • 4,281 Answers
First connect your router directly to computer with ethenret cable.
Then you can access it with defaults ip
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration page of router.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 24, 2009
  • 324 Answers
Connect the router with PC and you can find the manual for TV to find the network of the TV once you connected with the PC you need to change the ip address way to your TV network because your TV AND internet in different network once you change this router to the TV network with the help of IP address it will work
If the page does not open then you don't have a connection to the router. Make sure your cable is attached to the router and computer. You can't do the initial install wireless usually.
May 01, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
Internet setup
It should work "out-of-the-box".
Be sure to connect using "straight-through" (not "cross-over") Ethernet cables.
Connect from the 'WAN' port on the router to your DSL-modem (or cable-modem).
Power-off the DSL/Cable modem.
Power-on the DSL/Cable modem.
Power-off the D-Link.
Power-on the D-Link.
Reboot your computer.
You should be good.
Mar 09, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
JE NE PEUX PAS INSTALER DAP 1360
Access D-Link's support-site: ftp://ftp2.dlink.com/PRODUCTS/DAP-1360/
Choose 'REV. A' or 'REV. B' or 'REV.C'.
Download the instructions for your router.
Feb 16, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dap-1320 cant connect on internet
You posted your question in December 2013.
Do you still need an answer?
Dec 16, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
Cannot access either dlinkap or 192.168.0.50 via web browser in order to set DAP-1360
Connect your computer to the router.
Assuming Windows 7, click the "Start" button.
Into the search-box, type 'CMD' and press ENTER.
Type 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Nov 24, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dlinkap
You can do a reset to default settings. OR using the on-line setup, change/remove Security Key, refer to the User Manual here: http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201522/Manual/DAP%201522_Manual_EN_US.pdf
May 16, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
Cant open the link to setup the router
Refer to page 3 of the Quick Install Guide listed on the web site below.
There are multiple ways to configure this router and do not wish to provide HOW TO without knowing how you have it set-up.
www.dlink.com/products/default.aspx?pid=DAP-1522&tab=3
Apr 04, 2011 | D-Link DAP-1522 Xtreme N Duo Wireless...
Cannot connect to Dlink DAP-1522 at 192.168.0.50. Unit is plugged into home network router.
Hi. Is this to change its settings?
Plug directly in the DAP-1522.
Set your PCs network settings under TCP/IP, alternate config:
IP Address: 192.168.0.10
Subnet mask: 255.255.255.0
Default Gateway: 192.168.0.50
Give it a try.
Regards,
Nov 05, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Im trying to install a DAP-1522 as a bridge with my Linksys WRT610N V2. How do you do it. I find DLINK very hard to set up
Hi Friend,
Please follow the steps to install the DAP-1522
1) First connect your computer to the linksys router with a wire,dont connect the DAP. Now if u have windows XP please try this
2) Now ,click the start menu>run>type cmd and hit enter
3) In the black window,where the cursor is blinking type ipconfig/all and hit enter
4) Out of the bunch of information please note down the ip address and the default gateway
5) if the default gateway is 192.168.1.1
6) disconnect the computer from the computer and connect the DAP to the computer directly
7) click start menu>control panel>to your left you will see "switch to classic view",please click that>double click the icon named network connections
8) Inside network connection you will see an icon named Local Area Network connection,right click and click properties
9) under the general tab you will see Internet protocol(TCP/IP),select that and click properties
10) In the new message bos you will see 4 radio buttons,select the second one from the top
11) in the Ip address box type 192.168.0.1
12) Click ok and then close
13) now open the internet explorer page and delete evrything from the address bar and type the number 192.168.0.50
14) You will get the page of your DAP
15) set the fixed ip of the 1522 to 192.168.1.50,DHCP should be disabled.
16) Make sure that you have set the wireless password so that no other people can mess up with your network
170Save the settings.Once done unplug the bridge and enjoy working wireless.
Warm regards
Chiranjeet Mitra
3)
Oct 08, 2009 | Computers & Internet
Dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Aug 16, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
201 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
