Question about RCA R56WH76 Projection Television
R56WH76 Failed Convergence Fix
I have a RCA R56WH76 TV I got a year back that's FL231 fuse went out. I replaced that, it was a breeze! Only I didn't re-solder the flyback. So a year later it went out again.
I purchased the fuse replaced it but, I am afraid something went wrong. I am not getting any picture or sound now, the power goes on but that's all that's happening. I tried to turn the volume up (Nothing displays on the screen) and I don't hear the speakers hiss when you turn it too high. I tried pressing menu, of course, with no avail.
Thanks
  • 2 more comments
  • JonnyCarlyon Sep 24, 2009
    Sorry I should have added, there is no "high pitched" noise or anything unusual just the normal quiet noise that all these TV's make.
    Thanks for the fast reply. I located the cp150 but it does not look swollen or puffed up in any way. Any suggestions on what my next step should be?
  • Anonymous Mar 28, 2014
    How to replace the power cord to a rca projection TV model r56wh76
    How to replace the power cord for a RCA R56WH76 projection tv
  • RCA Master
  • 5,138 Answers
OK on same circuit board as fuse up on the front part of board look at capacitor cp150 if it is swollen or puffed up it is bad 2200uf 16v use 25v and replace 2 other capacitors in same area cp114 cp120 220uf 35v.
Posted on Sep 24, 2009
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at Ebay.com.No,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
The color from the projection is messed up and dnt know how to fix it
Go to Menu then setup Look for Convergence ,if you do not see convergence then you have a Blow Fuse on the Deflecton Board FL231 .06amps
Oct 23, 2010 | RCA R56WH76 Projection Television
Picture bends at top and bottom, colors distorted-rgb out of alignment tried realigning with menu-no sucess replaced convergence board-no sucess does it need some fuse replaced or could it be the high...
Go to menu then setup if you do not see convergence in menu then you have blowed fuse FL231 on the Deflection Board.
If you have convergence then with OFF Press and hold VOL- CH-
at same time wait till TV comes on release Now you should be in Factory Settings.
Oct 01, 2010 | RCA R56WH76 Projection Television
R56WH78 RCA TV FlyBack
Resolder all the pinns on the FBT chances are FBT is Bad they go out alot Call UED for Parts 1-800-648-6657
Oct 19, 2009 | RCA R56WH76 Projection Television
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
Rca 56 inch, picture looks like its in 3D
Go to menu then setup if you do not see convergence in menu then FL231 is bad it is on right side of FBT flyback Transfomer on the deflection board their is 3 of them in a roll small brown rectrangler looking caps but are fuses it will be the one in the Middle if fuse is good try this with set off Press and Hold at same time vol- and ch- see if set will come on this is How to Enter service Mode.
Aug 26, 2009 | RCA R56WH76 Projection Television
3d like picture, 3 colors bending across screen. convergence option gone from menu
There are bad solder connections on the flyback transformer and fuse #FL231 is open. Pretty hard to repair this yourself.
May 26, 2009 | RCA R56WH76 Projection Television
Convergence
Convergence. your convergence has failed. first questuion does the autoconvergence work.. in the customer menu under setup do you have the convergence option if you do not go to the tips and tricks section under my profile and read the article fl231 problem this is a simple inexpensive repair. NOw if you do have that option then you may need to replace what is known as convergence power supply
Oct 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
R56WH78 convergence problem
Get a new TV , i have had problems every year and now its off warranty, I will never buy an RCA again as long as I live,
May 13, 2008 | RCA R56WH76 Projection Television
Open Questions:
RCA R56WH76 Projection Television Logo
336 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
