Question about Dewalt 18 Volt Compact Drill Kit
Dewalt de9092 - the reverse not engages regularly
Dewalt de9092 - the reverse only engages one in every few i.e. 5 presses of button. i.e. not engaging motion everytime.
Fierce annoying, wont do reverse, then does but dont expect it. Line up with threads again and nothing happens.
  • 2,176 Answers
Sounds like the switch is bad and needs replaced, You can go to Dewaltservicenet.com and type in your model number to find a replacement switch, If you do it yourself make sure to write the wiring down first, the switch might be polarity sensitive.
Posted on Sep 26, 2009
Reverse not working. Pressing the reverse button isn't engaging the machine in reverse - the light has gradually stopped coming on, it appears to be disconnected.
take your machine to a Viking dealer and have them check it out. it probably has a worn 8 button keypad. the reverse button is usually the first to wear out. this not a DIY project.
Mar 10, 2015 | Husqvarna Designer I
Polaris 6x6 engine misses and awd don't engage in reverse.
awd will only engage in reverse if override switch on left handlebar is pressed will also skip if too much throttle is applied without override button engagement
Jan 14, 2014 | ATVs
Reverse fails to engage
you must do the reversing in correct order :
Engine running, transmission in neutral. Press Reverse button. Then press the starter button. The starter motor moves the bike in reverse.
Dec 22, 2013 | 1989 Honda GL 1500 Gold Wing
Instructions
From the manual:
Setting the Clock
1. Press and hold the Time Set Button until the display begins flashing
2. Press the Reverse or Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display
3. After setting the time, press the Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode
Setting the Calendar (It is important to set the correct date in order to use the 7-5-2 Alarm settings)
1. Press and hold the Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display
2. Press the Reverse or Forward Button to set the correct year, and then press the Enter Button. The unit will beep and the display will show the month and day. Again, press the Reverse or Forward
Button to set the current date
3. After setting the date, press the Enter Button or wait ten seconds to return to the normal display mode
Setting the AM/FM Radio Alarm
1. Press and hold the Radio Alarm Button until the settings and radio frequency appear on the display.
2. Press the Reverse or Forward Button to set the alarm time.
3. Use the AM/FM Band Button or the Memory Set 1-6 Buttons to select a radio station to wake up to. Adjust the alarm volume using the Volume Thumbwheel
4. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
5. After you have programmed the radio alarm, press the Enter Button or wait ten seconds to return to the clock display. The Radio Alarm Indicator will appear on the display, showing that the alarm is set.
Setting the Nature Sounds Alarm
1. Press and hold the Sounds Alarm Button until the settings and Nature Sounds Indicator appear
3. Use the Nature Sounds Button to select a nature sound to wake to. There is a choice of four sounds:
Sound #1: Ocean Surf
Sound #2: Forest Spring
Sound #3: Rushing Brook
Sound #4: Summer Wind
5. After you have programmed the nature sounds alarm, press the Enter Button or wait ten seconds to return to the clock display. The Nature Sounds Alarm Indicator will appear on the display.
Setting the Buzzer Alarm
1. Press and hold theBuzzer Alarm Buttonuntil the alarm setting appears on the display.
3. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
4. After you have programmed the buzzer alarm, press the Enter Button or wait ten seconds to return to the clock display. The Buzzer Alarm Indicator will appear on the display, showing that the alarm is set.
Dec 06, 2013 | Timex T309TT Clock Radio
How to set time on the TIMEX t309t
Please follow these instructions:
Setting the Clock
1. Press and hold the 5 Time Set Button until the display begins flashing.
2. Press the 10 Reverse or 14 Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display.
3. After setting the time, press the 15 Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode.
1. It is important to set the correct date in order to use the 7-5-2 Alarm settings. Press and hold the 6 Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display.
2. Press the 10 Reverse or 14 Forward Button to set the correct year, and then press the 15 Enter Button. The unit will beep and the display will show the month and day. Again, press the 10 Reverse or 14 Forward Button to set the current date.
3. After setting the date, press the 15 Enter Button or wait ten seconds to return to the normal display mode.
I hope I could help.
Thanks
Nov 26, 2011 | Timex T309TT Clock Radio
After using the hdmi cord, now trying to switch back to regular tv (red/yellow/white cord). Noted a few responses from similar questions, when in hdmi going to video settings but do not know which option...
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until it goes off again.
That's it.
If it doesn't work, try this:
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 2-5.
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
I have a Dewalt model 7730 radial arm saw. When the on button is pushed the motor starts off real slow as if it is under a bind or load but after a few seconds it picks up speed and seems to turn at full...
most probably it is bit of timber on the bottom of the saw assembly...
1. switch off the saw
2. remove power plug
3. remove screw and clear protector assembly
4. remove centre panel (as to changing the blade)
5. remove blade and clean dust furrow below it from all debris
6. re-assemble in reverse order
7. mount safety protector assembly
7, connect power cord
8. start in shor burst and switch immediatelly off, after blade stop spinning, check blade assembly if not wobbly.
this should solve your problem.
if you find this advice useful, please do not hesitate to leave comment and give me your vote4 fo rme, thanx!
Aug 02, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Aerostar transmission
The aerostar tranny cooler sits too low away from the trans and tends to become blocked and restrict the flow to the tranny It could not hurt to remove it and flush the cooler out I have had a few aerostars and I have had to flush them all,the tranny fluid came out very dark and smelled very burnt it may not solve your issue but maybe. It has solved a shifting issue for me the 1-2 is smooth as silk now.
Jan 16, 2009 | 1995 Ford Aerostar
The motor turns but the clutch will not engage
Take the drill out of the hammer drill setting when in reverse.  Using the drill setting with the speed on 1 will give the power to free the bit.  If the clutch will not engage, GENTLY but firmly switch between forward and reverse.  This should work just fine.   I hope this solution brings you success!  Best Regards,  Michael Mittelsdorf
Dec 26, 2008 | Drills
Clock radio, small
This little guy has the most complicated date setting procedure I have ever seen! From the manual: "Manual Time and Date Settings 1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing. 2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator. 3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting to lock into place. 4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year. 5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the 4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day. 6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place." You can download the manual from the link below: http://www.timexaudio.com/pdf/T307_IB56281_07.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 24, 2007 | Timex (T307S) Clock Radio
Dewalt 18 Volt Compact Drill Kit Logo
173 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
