Question about Smeg Dishwashers
No water filling dishwasher after paper napkin got caught up in wash and blocked drain holes.
    President:
  • 1,653 Answers
First turn off the mains power to the dishwasher then check the internal filter and screen and clean it thoroughly. Then check the waste water hose and any outlet valve and make sure that it is unblocked and free of any obstruction or waste material. If you have access to the water pump you can check that it is free of obstruction and is able to turn and that none of the impeller vanes have been damaged. Then if all this is OK then try turning on the mains power and running a hot wash cleaning cycle to flush out any remaining sludge / debris. If this fails and no water is entering the machine then the most likely cause of the problem will be a defective water inlet valve or logic controller board and both will need checking and / or replacing by a service engineer. In this case it is most likely that the water inlet valve has become defective and will need replacing. This is quite a common fault with dishwashers and washing machines and is a relatively simple and cheap repair.
Posted on Sep 24, 2009
I have an LG model LDS4821 dishwasher that quit washing clean. Top rack is the dirtiest. Water is hot and bottom drain is clean.
The most likely cause is a blocked or clogged wash arm. Many times when the wash stops the debris blocking the spray will back away. The holes in the arm are aimed to cause the arm to rotate. The clogged hole is usually an outer diameter hole which provides the force for the arm to rotate.
Some upper end washers have a blocked arm sense to alert when arm is blocked.
Careful not to deform the geometry of the hole when removing the debris. Tweezers work the best.
26281729-v4uvew3xjjdpgmn3ctj2lcyg-4-2.jpg Hope this helps?
Sep 13, 2016 | LG Dishwashers
Moyer Diebel 301 always draining
what I can tell you is that if the water temp is not high enough say 120 deg, the dishwasher washing cycle will extend.chk your drain hose and float valve for fill drain issue.
Feb 12, 2014 | Moyer Diebel 24 in. 301HT-40 Built-in...
After a cycle the dispenser is filled with water. The dishes are clean, the detergent is gone, but there is water filled in the dispenser. Thanks!
There is a small drain hole in the bottom of the dispenser. Most likely it is blocked. Try a toothpick or similar to unblock it.
Feb 11, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
Gene, I have a Kenmore Elite model # 665
Hey Steve,Sorry it took me so long to answer i was offline and my add is not supposed to displayed when i am off line so sorry about that.
Now then on that dishwasher with the hum and no water circulation it sounds as if the main wash motor is jammed up for some reason it could be that the motor itself is defective or as simple as something such a piece of debris such as broken glass or almost anything caught in the motor causing it to not turn on,by disassembling the wash motor you can see if something is caught in,if nothing is caught in its a (sorry to say) the motor itself thats bad and would need to replaced.The reason the water drains even though it will not circulate is because of the separate drain pump that is working Please reply back after disassembling the pump to check for debris if ya need further assistance.
Thanks for using Fixya.Com,GENE
Oct 18, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Heavy film left on dishes. when rinse only frunction is used in empty dishwasher with no soap, the door and interior are still not clean. soap scum remains.
Hi and welcome to FixYa, I am Kelly
Most of the time when you start having dirty dishes post wash there is either an internal blocked screen under the lower wash arm tower or a problem with the drain. The drain problem shows up mostly inside the Air-Gap cap or at the garbage disposal / sink port connection. Pull the cap / cover off of the Air-Gap and then NOTE the installed position of the inner cap. Unscrew the cap nut and lift the cap off of the Air-Gap assembly. Food particles block the drain inside the cap. You should see a blockage as soon as you lift the cap or the particulate falls away as you lift the cap. Look into the Air-Gap with a flash light and clear any debris. Re-install all Air-Gap parts after cleaning. Make sure to pull the hose off of the garbage disposal port and clean the port.
Add water via cycle fill and then test the drain cycle. The dishwasher should be empty in less than 90 seconds. After 90 seconds interrupt the drain cycle. There should NOT be standing water in the dishwasher sump. If you have standing water in the sump after 90 seconds you will have to remove the lower wash arm and tower to clean the screen or drain holes in the tower. (depending on modeL) Another thing to pay attention to is exactly HOW the lower wash arm is installed on the tower. Some of the 2 part lower wash arms can be a nightmare to re-assemble.
When in doubt take pictures first.... (Lesson learned the hard way too many times when a 30 minute job goes in to the 2nd hour on my time!) Just make sure you do NOT remove any motor pump mounting hardware where it mates to the tub base. Even loosening a motor pump bolt or screw can cause a leak after your done.
While the lower wash arm is removed make sure that you inspect and clean the inside of the wash arm. Often food particles can block the water spray holes in the wash arm.
IF you have a direct / no Air-Gap sink connection then pull off the hose at the sink connection and clear the connection hole of any debris.
One last thing to look for is clogged upper spray arm water holes. Just inspect for signs of blockage. Only remove it if you note food particulate in the holes or under the wash tower base.
I am speaking from many many years of in home appliance repair experience. The steps above should stop the dirty post wash dishes. If you still have the same issues please respond with an EXACT Make and Model Number so I can look at the mechanisms of your dishwasher before responding again.
Thanks for choosing FixYa,
Kelly
Jan 17, 2011 | General Electric Spacemaker® GSM1800N...
Diswasher is not draining. The bottom is full of water. What is the problem, how do I correct it?
always when posting make and model are very helpful. most likely there is something blocking the drain ports on the basin. the most common article would be the clear wrap of a tv dinner.. or something like that .. or a paper that was surrounding a can or bottle that you put thru your dishwasher cycle. most often it is reocmmended not to wash your recycling in the dishwasher as this is a common problem that can ruin your machine. is it new ? is this the first time using it? who installed it. would be my next questions and if it is any of the above then chances are someone didnt uncap and port for drainage... if you have used it before and now all of the sudden it is blocked then it is something like a paper or clear plastic blocking your drain ports at the base in the middle of the dishwasher you will see a grate with holes if they are blocked it will not drain.
Jan 02, 2011 | Dishwashers
Kudm01TJWH0 dishwasher is EXTREMELY slow draining. Plugging the drain into the disposal builds pressure (10PSI?), but no volume. Any ideas?
The bottom area of all dishwashers have the drain holes and pump which evacuate the water and debris. Remove the bottom tray and reach in and feel around. You may discover that some small items like corncob holders have fallen into the drain holes...If the drain holes are not blocked or clogged, the pump may be weak or defective. Check for debris first, if you find nothing blocking the little drain holes, call a repair agent who may need to get under the wash basin area by removing the washer from the cabinetry.
Oct 08, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Had blocked drain so water from sink backed up into d.washer. Drain clear but d.washer keeps emptying and won't fill
Make sure drain hose from dishwasher is higher than water inlet if not it will do just like a washing machine if the drain hose is lower than water level it will empty while filling.
Jan 19, 2010 | Dishwashers
Dishes on top shelf are not comming clean
Check these things out.
Debris caught in spray arm holes. Remove spray arm and clean out with water and compressed air.
Heating element burned out. Check water temp during wash--should read between 130 to 140 F.
Insufficient water fill in basin. In most models, proper fill level is just up to the heating element. Much less than this will result in poor cleaning.
Aug 12, 2009 | Whirlpool DU1055XTSQ Built-in Dishwasher
Dishwashers Logo
165 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
