Question about White Sewing 1418 Mechanical Sewing Machine
My bobbin wont feed through
When stiching on my janome - my excel 23l the bottom thread tangeled...i changed the needle and re threaded the bobbin...now the bobbin wont feed through...i also fiddled with the tension which I have on 4 and a black knob on the top left hand side of the machine under the flip cover which i fiddled and don't know where that should be.It has a 2 and 3....please help ....
    Sergeant:
  • 244 Answers
Take the bobbin out check for debris (pieces of thread, lint, etc.) that may be jamming the bobbin. check under the feed plate for a thread jam or debris. check if your bobbin is wound too tightly. it can happen! then it will keep breaking. the other adjustments are mainly for thread tension- the spool on top. if they're too tight, the thread will keep breaking. you can tell- once they're properly adjusted- by the quality of the stitch. check the bobbin first! if it's too tightly wound, you can probably adjust the winding tension on top. try a different bobbin. if that works then 'rinse and repeat!'.
good luck!
Posted on Sep 24, 2009
Testimonial: "thanku.The prob was the needle was incorrectly inserted & after adjustment the bobbin fead.the prob is the needle inserter moves 2 much,any ideas plz"
Thread keeps getting tangled in bobbon and wont sew
try a new needle
make sure the bobbin is inserted correctly,, counter clock wise
also check the upper thread tension, also check to make sure there aren't any loose thread or lint in the tension disc area
make sure the top thread has not come off the thread take up lever
check in the bobbin area for lint or loose threads
Dec 15, 2014 | Sewing Machines
My stitch length is tiny and will not change
When selecting a stich, there's a button with a triangle with one edge pointing down. There you can select Needle Position and Stitch Length. --PDF manual, page 23
The thread tension has no influence on the stitch length. It just adjusts, where needle thread and bobbin thread 'meet' inside the fabric. A too high tension means, the bobbin thread is pulled trough the fabric and can be seen on the upper (needle) side. A too low tension means, the bobbin thread is not pulled through the fabric and you can see the needle thread on the bobbin side.
Jul 08, 2014 | Janome Memory Craft 9000 Computerized...
Bobbin thread is jammin up after about 3 rotations of wheel on my janome 8077 - is this a timing problem?
try changing the needle
make sure the thread has not come off the thread take up lever
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not over filled
make sure the bobbin is not damaged
it's very possible that the machine could be slightly out of time
Sep 01, 2012 | Janome Sewing Machines
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
Material wont feed threw bobbing gets tangeled
try rethreading the machine top & bobbin--use different thread this time
try a new needle
clean under needle plate & bobbin area for loose threads & lint
Jan 10, 2012 | Baby Lock Sewing Machines
I am having a problem with my Janome Decor Excel 5018. It was working fine, until the bobbin thread won't gather with the top thread. And the top thread is binding up underneath the fabric. Kim
try a new needle
rethread the machine top & bobbin, that way you make sure the thread is not caught anywhere
make sure the bobbin is correctly inserted in the machine
clean under the needle plate & in the bobbin area for loose thread & lint
always keep a long thread tail of 3 to 5 inches long, & keep the tails pulled back behind the needle
before sewing
if none of these things help the problem,, then it may need to be serviced
Aug 10, 2011 | Janome D'cor Excel 5018
When i sew on my LS-1 the stiches are not catching sometimes they do for afew stiches but then get tangeled up at then end of the needle and starts to break
I would change the needle, in case there a burr or it's bent
clean under the needle plate & in the bobbin area for lint or loose threads
Aug 09, 2011 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
I have a janome 8050 sewing machine. It has started making loose stiches underneath and making a noise. I have changed the needle, bobbin, thread, cleaned the bobbin area. It will not make any stiches at...
The key to proper stitches is that tension on the bobbin must equal the tension on the upper thread spool as well. The bobbin has a tension screw that may have come loose or the thread is not properly in the tensioner. For example, the bobbin could be in backwards. Or the tension of the top could be too light and allowing the tension on the bottom to pull the thread down too much.
Open the bobbin tray and watch while you slowly rotate the hand control to see it make a stitch.
You will probably be able to figure out what is wrong.
Apr 08, 2011 | Janome Sewing Machines
Janome sewing machine Harmony 2139 The bobbin thread is not connecting with the needle to make a stitch. We have put in a new needle. Using needle 4 tension
Take out the thread. Now cut the end of thread using a pair scissors. Now try that again. Once i had the same problem and later found out that the uneven end of the thread caused problem by refusig to move around freely hence preventing the stich formation
Dec 02, 2010 | Janome Sewing Machines
The needle doesn't pick up the bobbin thread
check the following if the thread swiped properly if the needle is correct if the end turns grabber whether the shuttle is set correctly...
Dec 10, 2009 | Janome Sewing Machines
White Sewing 1418 Mechanical Sewing Machine Logo
266 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
