Question about HP Pavilion dv1000 Notebook
Cpu fan error
Every time lately i attempt to start up the comp it flashes error cpu fan failed and states it will shut down in 5 seconds whcih it does...but after numerous attempts i can get on an d stay on with no issues...its getting on that is the issue why is that ? if it fails shoudnt it never allow me on ?????
  • Anonymous Apr 29, 2008
    I have Emachine T2542 Every time I turne it up I just get the follwing message ups fan failed system will shut off in 5 minuts.
    I check the fan and it is spining, Put a new fan and the same message I get
  • 383 Answers
POST troubleshooting steps. If a fan has failed (especially the heat sink fan for the CPU)
Good Luck, Please dont for get to Vote.Thank you.
Posted on Dec 16, 2007
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Model# pcg 71318l
Overheating
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 29, 2013 | Sony VAIO Computers & Internet
CPU keeps overhreating.
Feb 24, 2013 | ASUSTeK COMPUTER ASUS P8Z68 DELUXE/GEN3 -...
I have Compaq v6608AU laptop. When I start the comp it gets booted and windows runs normally. After booting my comp suddenly shutsdown. what is the problem?
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
May 01, 2011 | Computers & Internet
I changed my cpu fan out, when i started it up it ran 30sec and shut down. So i replaced new mother board without fan., it still shuts down after a few sec. I disconected the 4 pin power source and it will...
From your problem description it sounds like the CPU was overheated (and failed) before you replaced the CPU fan - so the fan replacement was too late. Since the procesor already failed, installing a new motherboard without a fan did not accomplish anything.
The 4 pin power plug provides +12 volts DC to the processor. When you disconnected it, the processor essentially could not run at all and the system is no longer capable of detecting the CPU failure and shutting down the power supply.
You need to install a known good CPU which is the right type and speed for your computer. Unless you are experienced in replacing,CPU's, fans, heat-sinks and applying thermal grease I recommend that you have a PC technician perform these tasks.
If you believe that this information is of value to you please rate me on the FixYa website.
Regards,
Yavacotech
Nov 29, 2010 | Computers & Internet
[Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Fan error
You mite not want to reset this. This could be telling you that your fan is faulty/Dieing. If so then if it doesn't turn off your comp, your CPU will fry from the heat. Try replaceing your CPU fan within your computer. "Cool Master" is a good brand. you can find them at any Fry's Electronics Store.
Oct 05, 2008 | Averatec Sotec 3200 Series Fan with...
Will not start up
If it's not beeping during the first start up then it's not POSTing.  Beep means everything connected to it seems to be functional ie PnP
Try pulling out your memory and reseating it.   Try pulling out your battery for 5 minutes then plug in ac(without batt) and see if it will boot.  Try pulling your hard drive and reseat.  (access by covers on bottom...dont be scared. Touch something that's grounded just before you remove) If all this and still no full POST(with beep/s) then sounds like a new mobo or processor.
James Mac
Sep 09, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv1000 Notebook Logo
111 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
