Question about Neff B1644 Electric Single Oven
Neff 1031-2. oven door does not "pull close" but stays ajar. could this be a problem with the door seal as this is not fitted tight against the oven
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Re Neff B1451 oven door not sealing against oven body at top
The door hinges are not adjustable, the only solution is to replace both door hinges as it is the springs that are weak.
Go to; http;//www.youtube.com/watch?v=
Plz rate my solution.
Thanks.
Posted on Dec 30, 2008
barkencoa
  • 3463 Answers
SOURCE: Oven door isn't closed tightly on both sides.
If it is a door that lifts up and down, then the only solution is to replace both door hinges, as they are not normally adjustable, it is the springs that are weak.
Thanks.
Posted on Jan 06, 2009
barkencoa
  • 3463 Answers
SOURCE: how do i fit new
If the seals have what appears to be hooks at the corners, then unhook the old seals and re hook the new seals into the holes in the front of oven .
If no hooks, then the front of the oven needs to be unfastened.to replace the seals.
Thanks.
Posted on Jan 15, 2009
barkencoa
  • 3463 Answers
SOURCE: The handle for my Neff 1031-2 oven has snapped in
You should have no problem in obtaining the part you require.
Try this site.
WWW.ESPARES.CO.UK.
Posted on Apr 05, 2010
Door will not close completly
When you say "oven door will not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 08, 2011 | Ovens
Oven door does not close properly
When you say "oven door does not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Sep 01, 2011 | Neff B1421 Electric Single Oven
Neff u1661n2gb/05. main oven not working and shorts out electric when try to switch on. top oven works no problem
I had a problem similar. The bottom oven stopped working and the left hand set of controls and clock died. I had three figure quotes for repair. I took the main control unit out from behind the switches, its a pain to do. I took pictures of where the wires went to save confusion later. I removed the main switch unit from the control unit by gently pushing back the inbuilt plastic clips. dont loose the small white connector piece on the end of the switch shaft. I gently pulled the switch knobs from the front then the knob extensions through the same holes. once the unit was out I turned it upside down I could see where two solder tracks on the circuit board had burnt out. I gently cleaned them up and bridged the gap with two short tinned pieces of single core wire I had stripped. I used a soldering gun as it gets really hot really fast and wouldnt damage the components underneath. the only fiddly bit when putting it back together was locating the bottom edge of the control unit in the little gulley, I had to bend the edge of the gulley down to make it easier. Once it was all back together it worked. Half an hour and I saved £300! Now I have to fix the hinges on the bottom oven door as it doesnt shut properly at the top. Any ideas anyone?
Nov 16, 2010 | Neff U1661 Double circotherm super...
Oven Door not closing properly at top
the door seal is probably worn loose and ill fitting. Needs replacing
Oct 18, 2010 | Neff B1641 Single circotherm super...
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
How do i fit new door seals for an neff u1421 double oven i have the seals
Thanks.
Jan 14, 2009 | Neff U1421 Double circotherm Electric Oven
Thanks.
Jan 05, 2009 | Dacor ECS130 Epicure Electric Single Oven
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Neff oven u1420
Hinges not fitted properly,or possibly wrong hinges
Nov 03, 2008 | Neff U1661 Double circotherm super...
Neff B1644 Electric Single Oven Logo
91 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
