Back to:
Tags:
PC Desktops
Generic problem for all PC Desktops
Hd install
posted by abigdog4991 on Dec 16, 2007
system not reading boot dics
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 16, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
My pc can't find hard drive
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on hd install:
I don't want to Accept this solution
Solution #2
posted on Dec 16, 2007
Not Rated (0)
map9966
Rank:Guru Guru
Rating: 89%, 1303 votes
Enter BIOS, at start up press Delete key every couple of seconds. PC vary, some require pressing the F1 key or F2 and others reqire F10. Once in the BIOS you'll need change your boot order. Again PC's BIOS's vary. Usually Floppy is first, CDROM second and Hd 3'rd. Save Bios and restart. If you boot media is a floppy disk your PC will go there 1'st, than to the CDROM. If boot media still is not seen. Check connectors to the floppy and or CD make sure cables and power connectors are tight.
Thank You!
Can you Help with these PC Desktops problems?
PC Desktops
I am using someone elses computer right now because I do...
PC Desktops
Sims 2 double deluxe installation code
PC Desktops
Need upgrade to Tiger System 10.4
PC Desktops
How deo you start the pinnacal studio 12 dazzle ?
PC Desktops
have windows xp . bought SD card reader/writer cd-35.when...
Loading problems.
Repair Service
Find PC Desktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
