Question about Apple MacBook Mac Notebook
My mac power book G4 sceen went black. It's plugged in and can't get it to turn on
I had this issue on my old G4 white ibook.
It would turn on but not finish the boot because of bad contact of the graphic card (manufacturing default that occurs after a few years).
Cannot repair this since the graphic card is more expensive than the laptop.
Posted on Sep 25, 2009
  • 73 Answers
Try to reboot it
Posted on Sep 24, 2009
3 Suggested Answers
darksidegds
  • 21 Answers
SOURCE: oevrall screen is black
First off where did you buy the replacement screen? Second did that screen also come with new ribbon cables?
If you bought the replacement online and just installed it without reading the instructions or it didn't come with any then you have the reason there.
If you did read the instructions and followed the steps correctly, then did the replacement come with new ribbon cables and connect lines is the next part, because the reason the first screen failed was not only the screens dynamics, but the constant open and closing, bending causes the cables to get worn in the same area and eventually it will tear or just break. And since you stated that the hinges had broke first that automatically says that the screen will fail due to not being able to function as it should. So with that said, and your answer was YES to the new cables, then final step is to retrace your steps when installing. Because you forgot to reconnect something to have the screen light up. If the white light on the screen doesn't light up you will see what you see now.
I suggest you to goto ifixit.com they have a step by step with images to install or replace parts on all Apple portables. Just follow their instructions correctly to find your PowerBook and then use their install steps.
-Luke
Posted on Feb 12, 2009
rulds2008
  • 3866 Answers
SOURCE: my g4 power book screen is very dark
This is door to a poor backlight meaning the backlight needs to be changed out. Going to cost like $125 for the part if you do not know how to do it then a tech will need to get involved so tack on your labor. I hope this helps as it did dozens of people with the same issue. please do leave ratings and feedback for your free answer today.
Posted on Apr 27, 2010
My I book g4 has black screen it has the fan and chime noise but no screen it's black what can I do
Hook up an external monitor. If that works the inverter on the laptop screen went out. It's an easy fix and part to find or a repair shop can do it for you relatively cheap.
Aug 20, 2014 | Computers & Internet
MAC BOOK AIR,LAP TOP NOT ABLE TO BOOT NOR START
If nothing happens when you press the power button then the computer is most likely out of power - plug a charger in and it should work. If it still doesn't you might want to get it checked at a service provider. If something happens when you press the power button but the computer doesn't turn on, then please provide more information, explaining exactly what happens so that I can help you.
Dec 05, 2013 | Apple iBook G4 Mac Notebook
Powerbook g4
If you have the operating systems disk, you can boot from the disc, and once the setup come dump, choose password reset from the "utilities" drop down menu. Change your password, shutdown, and reboot.
Nov 03, 2013 | Apple PowerBook G4 Mac Notebook
I was using my I Book G4 when it stopped responding. I powered down and restarted. When it began restarting it went to a gray screen with a file folder in the middle of the screen. the file folder had a...
Hi ,
take out the battery for 5 minutes , this resets the computer , , if this does'nt work , put in a bootable disk and try to recover the system ...........let me know if this works , i can advise futher
Goodluck Roy
Aug 27, 2011 | Apple PowerBook G4 Mac Notebook
My g4 power book screen is very dark
Apr 27, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
When I turn on my 17" power book g4 I hear the drive and chime and see a blip of screen light up from the lower right corner of the screen but goes black right away. I have no software at this time. I...
Do you have this machine plugged into AC power? If not, you may just have a depleted battery, which would fit these symptoms perfectly.
The problem is not software related, because with a missing or empty internal drive you would get a flashing question mark folder icon instead.
Does the machine power off when the screen goes black, or does it continue to run with a dark screen? Common solution for the latter is to wait two minutes until the boot sequence sounds complete, then press the F2 button to raise the screen brightness. Failing that, you may have a blown-out backlight tube in the screen itself, which can be addressed.
Oct 18, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
I have a power book G4, it's about 4 years now, apparrently i can turn on the laptop but the screen just black out i cannot see anything on it what could the problems be? thank you
It could be the tube that lights the screen not working. best thing is to get it to a service centre.
You can use the mac by plugging in an external monitor to check that the mac itself is OK.
Aug 08, 2009 | Apple Computers & Internet
My portable hard drive is not recognized by my Mac G4 power book
You have to run mac tools that is on that hard drive prior to plugging it in.
Jun 14, 2009 | Western Digital WD Passport 250GB Portable...
Powerbook g4 will not turn on
pull the battery out, put it back in, plug the mac in, and hold down the power key till u hear the chimb
Feb 16, 2009 | Apple PowerBook G4 Mac Notebook
Apple MacBook Mac Notebook Logo
137 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
