Question about Altusen Aten CS62U-2 Port USB KVM Switch
Hi, the CS62U is connected with an HP8750 (win2000) and a MSI WIND NETTOP 120 (win XP home). It works perfectly with the HP desktop but the mouse is not responding anymore.
  • 16 Answers
Try this:
1. Disconnect your HP computer, so that only the MSI Wind is connected.
2. On the keyboard, hit [Numlock]+[-] then press [A] (this will auto-search for the computer that's connected, and connect both keyboard and mouse to that port).
Give XP a minute to detect new hardware. If XP does not detect the mouse, try plugging the mouse into a port directly on your netbook. If XP still does not detect the mouse, it's XP that's not detecting your mouse properly, not the kvm switch. :) If it does detect it, you should be able to then plug it back into your kvm switch and it should work at that point.
Note: if you get stuck with lights flashing on your keyboard, just hit [Esc] on the keyboard. That will reset the KVM switch.
Hope this helps!
Posted on Apr 23, 2010
Blank boot screen
It sounds like you have a faulty screen, if under warranty contact support for warranty, otherwise take to a local tech to see if the problem can be rectified.
Oct 05, 2013 | MSI Wind U100-030US Laptop
My keyboard and mouse wont work on my msi touch screen computer.can anyone help me please
if you have a recovery dvd then you may need to use it to get
access to your computer
Jan 24, 2011 | MSI Wind Top AE222027SUS PC Desktop
I HAVE MSI NETBOOK WITH window xp installed on it but it is not working (window xp) and i can,t reinstall or recover window pls help me
USING THE Installer of your XP installer to portable dvd drive it still not working to reinstall the windows. the problem of your msi netbook is the hard drive. may sulotion for that. used desktop CPU and put the harddrive of your msi and into the CPU of desktop. then Checkdisk your hard drive.
and after that finish the checkdisk. get your hard drive and put again to your netbook. and try to reinstall then XP.
thnx i hope am i share my knowlage
Jan 20, 2011 | MSI Wind U123-002US Netbook
Not working
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: http://www.aten.com/download/download.php#productGuide (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Oct 03, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
How to repair workstation, os are win2000 pro in workstation
do you want to reactivate the win220 pro installation on the harddisk which now you cannot access?
insert win xp pro install cd and run the repair process
or
if you have partioned the harddisk, simply do a new install on another partition, mark this active and now you should be able to boot up and access the old installation.
copy the non-microsoft programs plus personal data (everything that is not in the windows folder) to the new installation,
then run every single program from the new installation
good luck
Apr 18, 2009 | Computers & Internet
How to install hp laserjet p1505n network printer in windows 98
I can not find a win 98 driver for your printer on the HP website. DO yu have the instalation disk that was writen for win 98? If not try installing the printer through  the control panel. Either printers/fax or through install new hardware.The first being the preference. Some of the win OSs have printr drivers already installed.
If this does not work out, then the printer has no drivr available for that version of windows and you ewither have to upgrade to Xp or use a different printer which has a driver for win 98.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us〈=en&product=3435671&
Jan 02, 2009 | Office Equipment & Supplies
Key board and optical mouse - PS2
muito simples:faz o download dos drives do teclado e rato da versão superior á que tens.depois vais ao painel de control+sistema+hardware,e fazes a actualização dos controladores.
VERY IMPORTANT:COPY ALL DRIVES TO DESKTOP.
copia para uma pasta,criada por ti no ambiente de trabalho,com 2 pastas 1 de keybord-1 de rato,copia entao os drives das duas versoes do equipamento,para essas pastas,
ao iniciares a actualização dos controladores ,indica sempre a pasta com os drives respectivos.
BOA SORTE
ALLIENFENIX@HOTMAIL.COM
Sep 11, 2008 | Computers & Internet
Computers & Internet Logo
378 people viewed this question
Top Altusen Computers & Internet Experts
David Payne
David Payne
Are you an Altusen Computer and Internet Expert? Answer questions, earn points and help others
