HI, THE TV WAS WORKING GREAT. THEN THE POWER WENT OUT IN OUR NEIGHBORHOOD FOR ABOUT 6 HOURS. WHEN THE POWER CAME ON THE TIMER LAMP WAS FLASHING, BUT THE TV WOULD NOT TURN ON AT ALL, AND STILL, WILL NOT TURN ON. I DID PUSH THE RESET BUTTON, BUT THAT DID NOT HELP. WHAT CAN I DO TO FIX IT NOW??
  • 5,138 Answers
Without Knowing your Make and Model Number I am unable to help you!' You must Post this information in order for anyone to help you Thank You.
Posted on Dec 09, 2009
My Mitsubishi tv WD 73734 won't show a picture you can hear sound and it powers on and off lamp light red and timer lighter blinking
No TVs will behave that way due to a timer. TVs only will display a nag screen telling you to reset the timer. If your lamp is more than 2 years old, it is suspect of failure. Be sure you buy a lamp with an Osram brand or Philips brand bulb inside. Any compatible(knockoff)lamps will not perform as they should. Mitsubishi DLP TV Bulbs
These folks sell original Osram bulbs in their lamps and they have a 6 month warranty. I use them myself for repairs and really have had great experiences with them.
Sep 09, 2015 | Mitsubishi WD-73734 73" Television
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
I replaced the lamp on my XGC55X Sharp Projector and it worked great for 2 nights (roughly 6 hours). Now it goes to warm up, with the lamp light blinking, and will power down with the status button showing...
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary
Aug 06, 2011 | Sharp XG-C55X Multimedia Projector
Hi, i have recently replaced my projector lamp, as it would not power up when switched on the main led on the power button just flashed, after replacing the bulb the light continued too flash, i took all...
It could be the lamp life needs resetting or the filter life needs resetting. Hopefully so, otherwise it could be a faulty lamp module.
Good luck
Aug 02, 2011 | Vivitek D510 Projector
Mitsubishi WD-62525 TV will not turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it for a samsung ,it works like your mitusibishi:http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The ballast has a sensor that detects when it's not able to power the lamp or if lamp is not responding,it will flash red when that sensor detects that.When you say: "it began to roll like the vertical and horizontal hold did not work then the sound went out" Do you mean you where getting horizontal lines? If you did that could be the Dmd.his is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Usually when there's a green light it could indicate a problem with the power supply,sometimes some capacitors do go bad. Check all of this and comment on this answer to see how it went.
Apr 08, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
May 09, 2009 | Televison & Video
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
