Question about Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN All-In-One InkJet Printer
Tx Cancelled: Rx Fax Info Mismatch
Is it possible to send a fax manually and yet avoid this problem? Found 2 fax numbers from the same source but both returned this error report. My previous Brother Fax machine did not have any problem sending a fax to this problem number.
  • 2 more comments
  • Keith Hull
    Keith Hull Sep 25, 2009
    Have just resolved this problem myself. aknz
  • Keith Hull
    Keith Hull Dec 16, 2009
    Resolved this problem myself.
    I am using the FAX Manually. It is not connected through the computer at this stage.
    Follow this sequence using the printer menu on the printer panel:
    Menu > Settings > Device Settings > Fax Settings > Transmission Settings > Check RX fax info > Set to OFF position > OK
    Then go back to the FAX Window.
    Another possible problem is that the Fax Transmission Speed setting may be too fast for the receiving machine.
    To slow this down follow the same procedure as above to Transmission Settings > TX Start Speed > Set to 14400 bps instead of 33600 bps > OK.
    By doing both of these procedures, I was able to send the faxes without any problem.
    Regards
    aknz
  • fabulouslyfi
    fabulouslyfi Aug 01, 2012
    thanks so much for the solutions aknz. they worked perfectly. :)
  • fabulouslyfi
    thanks aknz, worked perfectly. :)
Can you tell me how you resolved it? Please Email me at:
PalpatineX@comcast.net
Posted on Dec 16, 2009
  • lmcdbt Feb 06, 2011
    Thank you so much AKNZ, worked perfectly. I tried both the 14400 bps
Mx870 fax
first check if there is noise on your phoneline , that is one of the major causes of failures in fax transmissions
Aug 21, 2014 | Canon PIXMA MX870 Wireless Office...
Rx Fax info mismatch
Fax with Popfax with no more sending errors, busy signals, paper jam or faxes lost. So easy to setup Popfax service: no phone line installation or hardware purchasing required. Usually it takes only a few minutes to decide which package to choose and to subscribe to an internet fax service. The only things required are a device (Laptop, PC, Tablet or Smartphone) and an Internet connection. Try for free!
Jul 30, 2013 | Office Equipment & Supplies
Error #059 TX Fax Info Mismatch
From TechSupportForum.com --this worked for me -- change the settings: Settings>Device Settings>Fax Settings>Transmission Settings>Check RX Fax Information>OFF.
Jun 28, 2011 | Canon PIXMA MX870 Wireless Office...
Canon pixma mx 860, I try to fax and get msge NG #059 TX Canceled: RX Fax info mismatch What do I do?? Canon faxing has been one problem after another for me.
its a message from the modem in the fax
make sure the line is ok and he cable connected to the right place
if not helping than its better to send to service
Aug 23, 2010 | Office Equipment & Supplies
Trying to send a fax and get the TX #0259 what does it mean and what do i do to be able to send the fax
tx/rx/#0259 is just the number of the fax sent or recieved and the next one will be 0260,it has nothing to do with the fax sending!Make sure the line is connected in the L on the fax and that there is a dailing tone!Good Luck!
Apr 07, 2010 | Canon FAXPHONE L80 Laser
INCOMPLETE TRANSMISSION RX FAX INFO MATCH
Hi have you tried to send faxes to another number ?
Feb 18, 2018 | Canon PIXMA MX310 All-In-One Printer
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
Fax error message = TX cancelled:RX fax info mismatch???? Cannot send fax - How do I fix this error - Not all faxes return this message
Two Issues:
1. The Transmission Speed of the MX860 may be too fast.
Solution: on FAX Menu go to Settings>Device Settings>FAX Settings>Transmission Settings >"TX start speed" and change to 14400 or lower (14400 worked for me).
2. The recipient FAX machine may be receiving by a different number than the one you dial. This may occur if you dial a free-calling no.
Solution: Go to Transmission Settings as above>"Check RX fax info" and turn it to OFF. This disables the mismatch issue.
Hope this helps. aknz
Jul 31, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN  All-In-One InkJet Printer Logo
2,400 people viewed this question
old marine
old marine
