Question about Kenmore 64192 / 64194 Top Freezer Refrigerator
Banging noise from fridge
I have an older black/beige kenmore electronic top freezer fridge, the model number is C646-8088881 Type TFA-18, 4.0 Volts, and 5.25 oz. I bought it from a newspaper add, and when i had had it for about a month i noticed this bang every so often. I had someone come in, who is not Kenmore specific, and he told me that it was the control or circut board that was going. It freezes food, and then warms on its own. I have had many spoiled milk bags, and nothing keeps for long. I was wondering if i should just get a new fridge, or if you know what is wrong with it. Thanks Pat
    Champion:
  • 249 Answers
If i was in your shoes i would buy a new one,sorry,close,eire
Posted on Dec 16, 2007
13 volts coming into condenser fan and compressor, why?
b9182e2a-157f-48cf-8eb0-0de1603fcb75.jpg44e9149e-2d2d-43bf-92b8-e7635dce1fe2.jpgKenmore has a model number like this example=> 321.123456 Can you look around the door frame for your model number? Not providing a model number makes it almost impossible for a technician to help answer your question. Thanks Sea Breeze
Apr 29, 2013 | Kenmore Refrigerators
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Loud clanging noise from Kenmore upright freezer
Check the condenser fan (outside at the rear) and check the coil isn't baking hot. Electronics or board wouldn't cause your symptoms. Check the simple things first!
Jul 10, 2012 | Freezers
Water is leaking into teferagerator, seemingly from the freezer compartment. It is a Kenmore Coldspot model 106.72132101 type 21 TFA.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 01, 2011 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Kenmore fridge. freezer top works, but bottom doesn't.
Either your fan has stopped working, or it is not defrosting. Take the back panel of the freezer off and see if the evaporator coil is iced over, if it is replace the deforst heater, and the deforst thermostat. If the compressor is running the fan if the freezer should be running. Also make sure both your fridge and freezer controls are centered. Putting the freezer on the coldest setting acutally shuts off airflow to the fridge.
Dec 05, 2009 | Kenmore 71192 / 71194
Refrigerator door keeps popping open
Level refrigerator with front 1/4-1/2 bubble too high in front.
Mar 08, 2009 | Refrigerators
Kenmore fridge with freezer on top/condenser bangs
check rubber mounts on compressor and also make sure fan is clear of anything that could be rubbing it
Dec 17, 2008 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Refrigerator condenser banging
yeah, you must have knocked the compressor when cleaning, sounds like one of internal spring/mounts in the comp' has dislodged.
replace the compressor is the only fix, unless you can somehow get to the lose spring.
Apr 25, 2017 | Kenmore 61282 / 61284 / 61289 Top Freezer...
64194 Daily LOUD running noise
Unplug, and take cardboard cover at bottom off using 1/4 nut diver. Look at the fan; is there anything touching it? Spin it with your finger. Wait a few minutes then plug back in. Is it comming from the roundish black thing the size of a basketball? If so its not worth fixing?GOODLUCK>>>
Dec 17, 2007 | Kenmore 64192 / 64194 Top Freezer...
Kenmore 64192 / 64194 Top Freezer Refrigerator Logo
389 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
