Question about Samsung Refrigerators
My samsung is cold at the bottom of the fridge and warm at the top
  • 909 Answers
Im assuming you mean the freezer is cold but the fridge is not . Most of the time these auto defrost fridges require a internal evaporator fan to draw the frost from the freezer to the fridge compartment. If the fan is stuck, it will not be able to transfer this frost. Before any major strip down, suggest you defrost fridge unit for approx 12 hours and start again. 90% of the time this will correct the problem. Almost certainly door was left open accidently for a period which resulted in this. Please let me know if not the answere.
Posted on Sep 24, 2009
We have a kenmore top and bottom with a warm fridge and a really cold freezer?
Check that the fan is operating. If the bottom of the fridge cold & the top warm then thats probably the issue.
May 30, 2014 | Kenmore 50522 / 50524 Side by Side...
Hi my refrigarator is not cold lost fridge temp
I have the same fridge its the sensors there hidden behind the back panel. there are 2. one at top and one at bottom. one of them will faulty. there cheap to buy and easy to fit.11_16_2012_11_30_22_pm.jpg
Nov 16, 2012 | Samsung RS2630SH Side by Side Refrigerator
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
FRIDGE AND FREEZER IS COLD AT THE BOTTOM AND WARM AT THE TOP
It is a thermostat problem. It can be fixed but is sometimes cheaper to buy a new one.
Aug 19, 2009 | Refrigerators
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
150 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
