My atapi dvd a dh20a3p dvd writer keeps comming up with same error when i try to burn using nero the error is power calibration error how do i fix this and do i need to update the firmware as driver is fully updated
  • cvgeeks May 11, 2010
    What version of nero are you using? Was it preinstalled on your machine when you got it? If so did it work fine before and then you started getting this message or did it never work at all?
    Scholar:
  • 131 Answers
I found the upgraded firmware for your drive here: http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153
Disks have a test area on them where the drive can test write to calibrate laser power for the disk. This power calibration error means that this test write has failed for some reason. The most likely causes are bad media, a dead or dying drive, or a bad power supply. Try different media. If it is getting that error on the same drive with different media, check out your power supply fast!!! If it is an oem computer, they tend to use a cheap power supply that is just good enough to run the computer. If your power supply fails, it can other things in the computer. Download something that can monitor voltage. As these are not always accurate but its a starting point. Perhaps try monitoring voltage while you try a burn. You can also try reducing power usage (unhook usb/firewire devices, unplug power to extra hard drives etc. If it is testing with bad voltages and/or if reducing the amount of power fixes it, stop using the computer and replace the power supply fast before you have more damage to your computer.
Hope this helps
Posted on Sep 24, 2009
  • 73 Answers
You may try to write on lower speed. It might be that disk can be written on this speed
I try to burn dvd using nero 7 but i get power calibration error (F:optiarc DVD RW AD-7700S) writing lead-out..... burning faild
Possible solution to your issue:
  1. on Desktop click Start
  2. select Control Panel
  3. click on Administrative Tools
  4. click on Services
  5. browse your way down to IMAPI CD BURNING COM SERVICE
  6. right click (on IMAPI) then select properties
  7. in the middle of the window, it will say start up type. Click on the arrow to the right and select disabled.
  8. make sure you click APPLY
That should take care of it.
Jul 20, 2011 | Sony AD7700S Optiarc DVD Multi Writer 8x...
My DVD writer ATAPI a dh20a3p does not read properly, stopped when 85% reading. I tried updating driver and firmware still nothing.
If the firmware has been updated then the drive is having the issue. need to change.
Thanks
Apr 06, 2010 | Computers & Internet
DVD RW doesn't write(power calibration error)
This may due to lens alingment problem or dust in the lens. Clean the lens using lens clear CD/DVD.
Dec 03, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
L DVD WRITER DVD burning problem
You may try to clean you laser lens using cleansing Disk but if it wont help you. It should be echanged with LG.
Sep 28, 2009 | Computers & Internet
Tried to burn a DVD using Power Cinema by going Create DVD, Author & Burn etc. Get to the end for the buring process and got a error code: FF037303. What does that mean?-
means you have a faulty or failed DVD burner (error is Power Calibration Error, returned through the ATAPI driver). Test with different /branded/ blank media, if none work then replace the drive.If you find one that works, stock up.
Jul 16, 2009 | JVC Everio GZ-MG130 Camcorder
Not able to write dvd on my lenovo3000Y500 laptop
A power calibration error is caused by the inability of a DVD-RW drive to use a DVD-R or DVD-RW disk, it first writes a bit of a data on the DVD then uses it to calibrate itself for the position of the lines. This however can be caused by a number of reasons, so try the following options one after the other, If option 1 does not work, go to option 2, etc.
1:) Matshita has problems with some cheaper brands, get yourself a very known brand DVD as a test like pioneer or tdk
2:) Using a higher speed than the media is meant for, try lowering your burning speed in nero, try the lowest even, let's see if helps
3:) You have a Lenovo as you say. If it comes with Sonic, please uninstall Sonic first, then uninstall nero, then install nero again. Sonic and nero tend to conflict. But even if you do not have Sonic, reinstall nero and apply all new patches.
4:) If option 3 did not help, update the firmware, that helps in a lot of cases.
5:) If even option 4 did not help, disable IMAPI Service (Work's in most cases):
- Launch Control Panel -> Administrative Tools -> Services .
- Browse for "IMAPI CD-Burning COM Service", Right-click on it - and select properties.
- Change Startup Type to Disabled.
- Click Apply and Reboot.
6:) The burner lense needs cleaning, please don't attempt this at home if you are not a mechanic, take it to service they will clean it.
7:) Drive failure, or drive burning out -- then it needs to be replaced, if none of the above helped that is.
If you overlock your computer that can also cause this problem but since you use a laptop I assume you did not overclock it. Let me know if any of the above helped and what the results were.:)
Feb 14, 2009 | Computers & Internet
DVD Writer not working
the device has a power callibration error, meaning that it cannot apply sufficient power to the laser head, to burn your disks.
Alternatively the laser head may be-weak, out of alignment.
this is a Drive error, you can try a CD head cleaning Disk.
The problem, could also relate to the motherboard not supplying enough power the actual drive itself.
ensure you have a full battery, and A/C adaptor into the laptop.
also try uninstalling-re-installing nero.
if all this fails, consider a repair or re-placement DVD Rom.
Mike @ compurepair.
Feb 26, 2008 | Computers & Internet
Power calibration area full
There are many facts cause "Power calibration area Full" error. First of all clean up your TEMP files. Make sure DVD media you are using is supported by you DVD Writer. CDs are rather easy to write. DVD requires more precise laser beam to channel as its more dense than CD. So physical facts like dust on the lens might be a factor too. Also firmware update for your DVD Writer will be a great step. These are the main factors.
Good Luck
Dec 30, 2007 | Fujitsu Siemens AMILO Pro V2010 Notebook
Problem with burning dvd on imation dual layer dvd burner
You seem to have a related problem, you can't burn cd's and you cannot install windows without an error. Either your hard drive has a bad sector where it keeps trying to write the data or your dvd drive has a reading error. Firstly check your hard drive for errors, right click on your 'c' drive and down to properties, then click on tools tab, then error checking. This can take quite a while, so be patient. Secondly, there have been numerous updates from Nero especially related to Service Pack 2 so download the latest updates from their 'Ahead Nero' website, they are free as you are'nt upgrading just updating. Your ratings are important
Nov 23, 2006 | Imation (01932) CD-RW Burner
Computers & Internet Logo
1,688 people viewed this question
David Payne
David Payne
