Question about Bosch Dishwashers
My bosch classixx dishwasher won't drain - Bosch Dishwashers
  • 909 Answers
It doesnt take much to stop a drain motor from rotating. If you dont know the bosch washer, you will find it almost impossible to get into it One thing, if the door is opened, the bottom tray removed then the sieves untill no loose items are left, you will notice a little piece of plastic that can be pulled out to allow you access to your drain pump impellar. Remove the obstruction and turn with your finger. Does it turn easily.? if so reassemble and try again.(note if you dont replace the plastic part back properly, the pump will run but not pump correctly.)
Posted on Sep 24, 2009
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Water will not drain from my bosch classixx maxx freedom dishwasher
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 14, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch classixx dishwasher saying check water also not washing or spining
Bosch dishwashers have a food filter to catch food particles. You have to clean it occasionally, or it plugs up and stops water flow. This could be your problem. (Most other makers use a little grinding blade to finely chop the particles so they can be sent down the drain.)
Oct 04, 2010 | Bosch 24 in. SGS43C12 Classixx...
Bosch Classixx Dishwasher stck in one program
the module must be changed. let me know what happens. im a old bosch tech
Nov 09, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch dishwasher with these numbers inside door
i solved the problem by going to bosch uk website and one of the numbers came up when i went to download instruction manual
so that solved problem. thanks for your help.
Sep 17, 2009 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Water leaking from dishwasher
check the hose in the back to see if it split could be dry rotted
Jan 09, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch 24 in. SGS43C12 Classixx Free-Standing
if no drain, then no cycle. problem is probably that draining is not taking place. check the following: if plumbed in under the sink, remove drain hose from spigot and check no blockage. start any program - all programs start with drain. listen carefully for a low humming noise. if you hear this, it means you have something stuck in the pump impellor - bit of bone, cocktail stick etc. get back to me if you like with what you find
Jun 26, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
874 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
