Question about Samsung Heating & Cooling
How to clean my samsung aircondioner unit? - Samsung Heating & Cooling
    President:
  • 267 Answers
HI, Step 1 Your first step to getting your air conditioner to run better is to do proper maintenance. First turn the unit off.
  • Step 2 Next, you will need to remove the filter and see if it needs cleaning. Most time this alone can make it run better. Sometimes more is needed.
  • Step 3 If cleaning the filter worked, then you are done. If not the following steps can be followed. Unplug your unit.
  • Step 4 Remove it from the window.
  • Step 5 Using the tools needed, take the casing off of the unit.
  • Step 6 Set the casing aside. Look at the unit itself, is it covered in dust and build up? If so, taking a cloth gently clean off the debris.
  • Step 7 If you notice that there is more debris covering the unit all over, you can take a water hose and spray out the unit. Although this is not recommended, I have done it in an attempt to getting mine up and running.
  • Step 8 Once you have cleaned the unit itself. Take the glass cleaner and cloth, cleaning both inside and outside of the casing. Allow it to dry for a few moments then reassemble. Plug in your unit and check to make sure it is working before putting it back in the window, there isn't needed in putting a unit in that still doesn't cool.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • If cleaning the unit doesn't help it to work better, than having it serviced by a tech is a must if you choose to keep and not replace.
    • Again I do not recommend the water hose. I done it myself risking tearing the unit up completely.
    thank you,
    vijay (vote for me)
    Posted on Sep 24, 2009
    Conair portable aircondioner manual
    Try this site:
    http://www.conair.com/cnt_ib.php?action=filter&type=category
    Jan 23, 2013 | Conair Heating & Cooling
    I purchase this aircondtioner at Bestbuy in August 2010. I use it for maybe a month. I live in Connecticut so you only need an Aircondioner June thru September when it is hot. I turned my aircondioner on...
    Hello, if the unit is blowing warm air it could be due to 1) low airflow due to dirty air filter or evapoartor coil 2) low refrigerant charge 3) compressor is not engaging. check the filter first an let me know if it is clean
    Jun 08, 2011 | Frigidaire FAA068P7A Air Conditioner
    EC Reset botton is on.I got the aircondioning recharged,but no use .aircondioningstill not working ,I was told there is no leak in the system detected
    you should erase fault in AC control unit using diagnose CPU after recharging AC gas till then it won't be working,
    Apr 16, 2011 | 2001 Mercedes-Benz C-Class
    Danby standup aircondioner ( 3 in 1) , does not MODEL APAC9030
    If you receive an answer to this I have the exact same problem... dougakers at msn dot com
    Jul 13, 2010 | Danby Heating & Cooling
    Hi, I am going to purchase a 12000 btu 1.5Hp portable aircondioner unit for my living room of around 42 m^2 (7 metres wide and 6 metres in length). I am wondering if this unit is suitable for the room?...
    Hello =D
    12000 BTU will cool approximately 450 to 550 square feet. That's around 137 to 167 m/2.
    Unless your name is Beelzebub and the room your trying to cool is really really really really south (or in this case down). =D <that's not two horns is it? ";-} That should be more then enough to keep everything cool.
    Good luck and I hope this helps.
    Dec 27, 2009 | Heating & Cooling
    Aircondioner was running power shut off in house for about 3 seconds came back on airconditioner will not oower back on
    O.K check the following: one if you have a "newer" unit, they have a "built-in surge protector, if the light is red,and (or) off, go to the breaker box and shut it off for at least 3-5 minutes, it has an internal reset, better known as a "relay" that will reset itsself, and then try turning the unit back on just like you alway's would, if it is a "newer" unit right where it plugs in there is a "reset Button " there also, but only if it doesn't start the first way I told you, try pushing the reset on the plug next, if the first didn't work ,the second will, please let me know if I can be of more help, god bless and happy 4th....
    Jul 05, 2009 | Heating & Cooling
    Aircondioner dosn't Cool
    re gas the unit
    if problem persists check for a blockage but this sort of work can only be done with special machine and is beyond the scope of a home repair
    Aug 24, 2008 | 2004 Toyota 4Runner
    Hvac problems
    control board low voltage problem
    Aug 18, 2008 | Goodman CLQ36AR49 Air Conditioner
    Maytag air conditoner
    Unless you can see if the fan is hitting something, you can't. You will need to take it to a repair shop. Sorry.
    Jun 09, 2008 | Heating & Cooling
    Heating & Cooling Logo
    120 people viewed this question
    Top Samsung Heating & Cooling Experts
    billconfused
    Ezewudo Onyekachi
    Ezewudo Onyekachi
    Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
