Question about British Telecom Lands Phones
My phone rings once but cut off. Is this a line
My phone rings once but then cuts off. Is this a line fault or something wrong at my house? I can still make outgoing calls. BT say there is a fault but can say whether it is them or me. If it is a fault at my end they want to charge my £125 call out charge. I have removed the main socket casing and tried an analogue phone in the test socket and the same problem happens. I have also tried seperating the phone line from the internet but that didn't work either. I am not a technician but i dont want to call out someone and get stung for £125.
    Problem Solver:
  • 6 Answers
If when you plug into the test socket the line still fails then it is an external fault. BT are responsible for all wiring going back to the exchange from the back of the master socket - the repair should be free.
Posted on Sep 24, 2009
When receiving calls on my triple cd445 cordless phone it would ring once or twice and then cut off.How can i solve this problem
Unplug them all overnight, phone jack and power bases. Plus any other phone line devices, faxes etc. Plug the base unit and get someone to phone you. Then plug each unit in one at a time with a phone call in between. One of the units may be exceeding the REN number of units on your home phone line with all the devices you have.
If that doesn't pin point it, contact your phone service provider as you may have line problems including bad connections to the house itself. All your wires sit in boxes outside..
Jul 05, 2016 | Lands Phones
Phone rings once then cuts off. Can ring out OK.
Something has a shorted the line, unplug all phones, then call your line with a cell phone and see if it is still happening. If so, you will need to call repair. If not, plug 1 phone in at a time and call your number again, and repeat until you find the phone causing it to trip ring.. also if you do not have a inside wire maintenance agreement with you local phone company, start the test at the network interface device..
Aug 11, 2015 | Lands Phones
I have aquired a toshiba dkt2010-s digital business phone, and when i hook it up to the line at my house all i hear is clicking, what am i doing wrong?
phone line is not on. call service provider and have them cut the line on....they will only cut on the line you are using, and not ALL the jacks in the house!!! ...call and tell them you want this one cut on, someone may have to come out, but may be able to do it over the phone! Good luck
Jun 12, 2010 | Lands Phones
There is a fault in-house with my BT Inspiration Telephone system
Well BT is very simple it is just a pair of wires that all connections are in parallel, so what you need to do is check between BT jacks, look for disconnection &, shorts. use Cut and test method, IE: Go to each, BT, cut off any Going away, cables, temporarily, and test that line, if Ok, then connect up the Going Away cable and test again, go to next BT and do the same until you find your fault. ALL connections are on 2 & 5 in the BT jack. With the faulty section simply replace with any lightweight 2 corr cable and terminate on 2 % 5 in the BT jack,
May 19, 2010 | Inspiration 7.6 for PC, Mac
Getting to answer phone before fax or message bank cuts in
to stop the pixma from picking up even after the phone line has been picked up you need to ensure the telephone line is connected to the LINE port and not to the PHONE port on the back... the PHONE socket is if you wish to connect a phone line to the same socket Thru the pixma. (passthrough)
not sure how to stop the pixma picking up on the first ring though..... are you sure that you are SAVING the setting change.....?
Sep 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
I have a Panasonic KX-TG7210ET Quad set. For some reason when anyone phones the house the phone rings once and cuts off the call, usually before I can get to it. Also the Caller ID which used to work...
I think something is broken.
Try unplugging all phones and see if it still trips the ring. If it does, you have a wiring problem if not, probably a bad TG set.
Carl
Aug 25, 2008 | Panasonic Lands Phones
Answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Mar 28, 2008 | Uniden Cordless Phone
Rca executive phones
if on 1 and rings on line 2 which line is cut off?? 1 or 2??
if line 1 then you have a cross connection if its line 2 then you have a centrex problem and thats the phone company.
Feb 26, 2008 | RCA 25202RE3 Corded Phone
Lands Phones Logo
1,040 people viewed this question
Top British Telecom Lands Phones Experts
honeybun1986
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
