Question about LG 24" Built-In Dishwasher - Black
"LE" Error Code appears on control panel
"LE" appears on control panel. Water not entering dishwasher.
  • 725 Answers
LE is a motor error Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked. REMEDY Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Posted on Sep 27, 2009
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
What is error code LE?
An LE error code means problems with the motor. It can either be load issues, excessive suds, thermal overload protection, or a new installation. To solve this motor problem, you must first uncover the underlying cause.
Mar 24, 2015 | Samsung 24 Dishwasher DMT300RFS
HOW TO FIX LE ERROR CODE ON SAMSUNG DISHWASHER DMR78AHS
An LE error code on your dishwasher stands for "LEaking."
There is, what I call, a drip pan on the bottom that the water is dripping into. Remove your dishwasher and take off the lower the side panels to get a look inside the drip pan. If you have water in there, try to find out where it's coming from.
If there are no signs of water, tip the dishwasher over on its side and remove the plastic panel on the bottom of the dishwasher. Once removed, you can disconnect the connector to the leak sensor (it's mounted upside-down, with 4 wires coming out of it. If I remember right, the wires are blue and red).
Flip the dishwasher back upright and plug it in and see if your LE error code pops back on. If it pops back on, then you have a bad board. If it doesn't, then you either have a leak, or the "fangs" on the leak detector are shorting out, somehow.
Oct 29, 2014 | Samsung Dishwashers
My dishwasher starts, then "LE"
The LE error code indicates a motor error. This can be caused by a foreign object that is jammed in the impeller, a failed pump motor or a bad electronic control board.
Refer to page 26 on this link: Dishwasher/LDS5811_Service_Manual.pdf
I would check your warranty and see how long the motor has a warrany.
Hope this helps; remember to rate and comment this free answer.
Jul 28, 2011 | LG Dishwashers
I get an LE error message on my LG Dishwasher. I replaced the pump. Still get the LE error. Replaced the main control. Still get the LE. No blockage in the pump. What now?
When you receive the LE error code, unplug the machine for approximately 15 - 20 minutes. This will reset the microprocessor.
Oversudsing is the main cause of LE error codes. Using non-HE detergents or too much detergent will cause stress on the motor. Oversudsing can also cause leaking and odor.
A breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire.
A couple of notes about this - there are at least three motors on this unit - the main pump, the drain pump, and the 'vario motor' which appears to control the direction of water flow through the sprayers. The main pump is the one likely to go bad. Another cause of the LE code is broken wires in the door. The wires in the door get stuck in the black sound insulation and eventually break. Sometimes, this causes the LE error code. Check the wires in the door first. They are located behind the large front panel. It's easily removed by undoing 6 screws.
Sep 06, 2010 | Dishwashers
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Remedy:
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LG LE Error
The broken wire would be where the wires pass from the bottom of the door into the dishwasher body. A more likely cause may be a motor problem. A number of main motors have had problems with the magnets coming loose or breaking up, resulting in the LE code. You can remove the phillips head screws around the sump cover to gain assess to the impeller, which is attached to the end of the motor shaft. (via a LEFT HAND THREAD screw.) Turn the impeller by hand and listed for noise. Shaft should turn freely, smoothly, and quietly. If it does not, remove the impeller and the cutter bar, remove dishwasher from cabinet, lay it on it's side, and remove four phillips mounting screws from motor and wiring. There is a two year warranty on all parts.
Aug 19, 2008 | LG LDF6810 Built-in Dishwasher
LG LDF7811ST 1E code
Are you sure it's 1E and not LE error code??  The symptoms you mentioned indicates that it is an LE error code and the motor has an issue.  You will need to call a qualified LG technician to diagnose and resolve the problem.
Jun 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Error LE on display of a LG dishwasher model LDF 6180WW Leaves water in the bottom of unit
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
(Just copy and past the above link in your web browser)
Thanks
Jun 27, 2008 | Dishwashers
LG 24" Built-In Dishwasher - Black Logo
185 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
