Question about Nokia 6085 Cellular Phone
I have 3 micro sd cards the problem is that i forget the password so how i will get it... icant format the card also... my imp data is der
    President:
  • 1,462 Answers
HI
You have to choose the simple way to remove the password in your , Follow the steps below...
Insert the memory card into the card reader or any mass storage device into your computer
  • go to the file <memorycard>:/system then find the file "mmc store".and rename the file to "mmcstore.txt" (Hidden file should be made as shown from tools->Folder option->Show hidden files)
  • Now open the file in notepad ,
  • No you will see the password.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Sep 24, 2009
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
I have forget my memory card password which use in nokia 2690
If you lose or forget the password for your phone's memory card, there is no way to recover the password or access the data, even by taking your phone to a Nokia Care Point.
However, you may still be able to use the memory card if you can successfully format it. Formatting the card will not work in every case.
Formatting will erase all the data on the card.
To format you memory card:
1) Select Menu>Memory. Your phone shows the details of the memory card.
2) Select Options>Format memory card.
Thanking you
davevipul197
May 11, 2011 | SanDisk 2GB microSD Memory Card
My micro sd memmory card has benn locked by a password by sum1 and it cannot be opened in any way so is there any solution i can open it. and i dont need any data in the memmory card. i just need it to be...
The micro sd has no lock tab to slide on the side, but the SD card adapter does. Unlock the SD card adapter, and format the micro sd card using a laptop or PC. The only way your micro sd card could be password protected is using encryption. If this is the case, formatting the card should remove the password.
Mar 10, 2011 | Lands Phones
I forget my micro sd memory card password please solve it
u can format using card formater which is sold in retail shops , but it will erase all the data present in it
May 20, 2010 | Kingston 2GB Secure Digital Memory Card
Unlock 1 GB micro sd memory card
No, there is no other solution other than formatting the memory card. That is why passwords are dangerous friends. It should always be such that you can remember it without writing it down anywhere and not forget it.
Jul 29, 2009 | Nokia 5800 XpressMusic Smartphone
I have forgetten the password & have to remove it
try the last four digits of your phone number
Jul 27, 2009 | Lands Phones
Recovery or resetting of password of micro-sd crad of 6233
u will have to format ur card....format it and it will be reset but all the data stored will be deleted once u format it
Nov 30, 2008 | Nokia 5300 Grey Cellular Phone
Unlock 1 GB micro sd memory card of Kingston Made
hi this is Aravind , i'm having 1 GB micro sd memory card for my mobile nokia 6233 ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not openinng its asking for password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card without losing the data in memory card ... plz help me out ........
i have microsd card 1gb card of kingston. it is locked & i want to unlock my memory card without losing my data. so pls send me tips for unlock the meemory card
i forgot my password...pls help me unlocked it without losing my files n data... i forgot the password of my micro sd memory card 1 gb , i don't bother about data, how to open , pl explain.
Jul 19, 2008 | Nokia N95 Cellular Phone
Nokia 6085 Cellular Phone Logo
91 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
