How can i find serial number ql420 with snmp
How can i find serial number from ql420 with snmp ?
Can a Box Switch Record Logs and Alarms After a Loop Detection-enabled Interface Detects a Loop?
A fixed switch (such as S2309TP-EI-DC) can record alarms but not logs after a loop detection-enabled interface detects a loop. The configurations are as follows:
In V100R005 and V100R006, you can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection. If snmp-agent trap enable has been configured globally, the alarm function has been enabled.
Loop detection and loopback detection have been available since V200R001. You can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection and run the snmp-agent trap enable feature-name lbdt command to enable the alarm function for loopback detection.
You can run the display trapbuffer command to view alarms.
Jul 18, 2016 | Computers & Internet
What Files Will Be Displayed in the Flash Memory in Addition to the Default Startup System Software Package and Configuration File?
After a device is powered on, it initializes the configuration by reading the configuration file from the flash memory. When you run the dir flash: command in the user view, the following information is displayed:
<HUAWEI> dir flash:
Directory of flash:/
Idx Attr Size(Byte) Date Time FileName
0 -rw- 812 Jan 01 2008 00:00:56 private-data.txt
1 -rw- 948 Jan 01 2008 07:16:55 vrpcfg.zip
2 -rw- 90,602 Jan 03 2008 03:58:15 v200r008sph001.pat
3 -rw- 6,418,980 Jan 19 2008 20:19:42 s2700-v100r005.cc
4 -rw- 12,240 Jan 03 2008 04:52:43 $_patchstate_reboot
14,632 KB total (8,228 KB free)
In the command output:
· The private-data.txt file saves service initialization data. Initialization data of some tasks is irrelevant to the configuration and is not recorded in the configuration file. The private-data.txt file records initialization data of these tasks, for example, the number of times the device restarts.
· The $_patchstate_reboot file records the patch status. This file is created after the device runs a patch and cannot be deleted. The file records the status of all patches, for example, the active state and running state.
· The v200r008sph001.pat is a patch file. The file name extension of patch files is .pat.
Sometimes, the flash memory saves a notilogindex.txt file. If a destination host is configured for Inform traps, the number recorded in this file is used as the initial serial number and filled in the Request ID field in Simple Network Management Protocol (SNMP) packets. The system starts a timer when the SNMP task starts and updates the file every 12 hours.
May 10, 2016 | Computers & Internet
Unable to install c309a driver
no - enable snmp protocol in windows 8
https://www.loadtestingtool.com/blog/general/how-to-setup-snmp-monitoring-of-windows-system/
https://www.garlandtechnology.com/blog/enable-snmp-on-windows-8
Jul 25, 2017 | HP Photosmart Premium C309A All-In-One...
How to enable ZPL on a QL420 wifi printer
Include this command before the start of your ZPL code:
! U1 setvar "device.languages" "ZPL"
Apr 20, 2011 | Zebra QL420 Thermal Printer
Buenas tardes No he podido ingresar a configurarlo...lap1242ag
Puedes conectarte via web, serial o SNMP para ver como conectarte revisa el procedimiento en la siguiente liga http://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgch2.html
cualquier duda o comentario me avisas
Mar 18, 2011 | Cisco Aironet 1200 AIR-LAP1242AG-K9...
Have a canon pixma mp560 every time I print it says printer paused how do i fix
try these steps:
Setting SNMP on the Device SNMP helps monitor the state of the machine and collects information on it. The following items can be set:
<Community Name>: Sets the SNMP community name. You can specify up to two community names. <Writable SNMP>: Enables the computers on the network to access the machine and modify its settings if this item is activated. You can specify this setting for each community separately. <Get Printer Management Information from Host>: Enables automatically the SNMP port monitoring function to obtain printer management information such as information on print applications and printer ports, if you are using Windows Vista and set [Standard TCP/IP port] for the printer driver port. 1. Press (Additional Functions).
Press g0014901.png (Additional Functions). 2. Press [System Settings] 7400rightpointer.jpg [Network Settings] 7400rightpointer.jpg [SNMP Settings].
If the System Manager ID and System Password have been set, enter the System Manager ID and System Password using g0015291.png - g0015292.png (numeric keys), then press g0015353.png (Log In/Out) to enter the System Settings menu. The SNMP Settings screen appears. 3. Select [On] or [Off] for <Use SNMP>.
[On]: When you set or browse each item of the machine with utility that uses SNMP to obtain information. Proceed to step 4. [Off ]: When you do not use an SNMP utility. Skip to step 7. 4. To change Community Name to a name other than <public>, press [Community Name], then enter the community name using the touch panel keyboard.
5. Select [On] or [Off] for <Writable SNMP>.
[On]: Allows the computers on the network to access the machine and modify its settings. [Off ]: The computers on the network cannot access the machine and modify its settings. 6. Select [On] or [Off] for <Get Printer Management Information from Host>.
[On]: Enables the SNMP port monitoring function to automatically obtain printer management information such as information on print applications and printer ports if you are using Windows Vista and set [Standard TCP/IP port] for the printer driver port. [Off ]: Disables the above function. 7. Confirm the settings you specified, then press Turn off the machine, wait at least 10 seconds, then turn it on. [OK].
8. Press [Done] repeatedly until the Additional Functions screen closes.
9. Restart the machine.
Nov 06, 2010 | Canon imageCLASS MF7480 Laser Printer
I have and Canon iR3570 and when SNMP is disabled the printer goes offline and network printing ends. Enable SNMP and change the default community to something more secure and printer goes offline and...
It's possible that the SNMP Status Enabled box is checked on the print server (Printer/Properties/Ports/Port Settings). When you disabled SNMP or changed the community name on the printer, the server was no longer getting status updates and so flagged it as offline. Make sure the community names match.
Aug 31, 2010 | Canon ImageRUNNER 3570 Copier/Printer
We have Phaser 7300's. Our secuty team tell me that we must remove a SNMP Default Community Name vulnerability ny 1) disable or remove snmp services, 2) disable or remove the detected community name of...
1. Open the web management page in your browser. Just put in "http://xxx.xxx.xxx" where the IP address of the printer replaces the x's. 2. Click on "Properties" 3. In the box on the left side, click to open the "Security" folder 4. Click on "Security Settings" 5. Find the line for "SNMP Read" and uncheck the box under "Any User" 6. Find the line for "SNMP Write" and uncheck the box under "Any User" 7. Click on "Save Changes'
That should cover it. Also posted a video showing the steps on youtube. Should be linked from here.
Feb 02, 2010 | Xerox Phaser 7300DN Laser Printer
Conversion of SNMP to TCP/IP packet
Hi!
I suggest the following:
Install a packet analyzer to the target machine.
This program helps you observe and analyze the network traffic real time. It is helpful for debug the network packets, look inside how the frames is structured. The Wireshark is quite popular debugger tool. Install it and check TCP/IP and SNMP packets with it.
Here is it:
http://www.wireshark.org/download.html
Second:
There is a lot of information on the internet about the SNMP freame formats and TCP/IP protocol.
Here are some useful links:
http://www.tcpipguide.com/free/t_SNMPMessageFieldDefinitionsGeneralMessageFormatand.htm
http://www.dpstele.com/layers/l2/snmp_l2_tut_part1.php
http://www.rane.com/note161.html
A lot of RFC documents write down the SNMP protocol.
Here are somple helpful VC++ programs:
https://www.planet-source-code.com/vb/scripts/ShowCode.asp?txtCodeId=7949&lngWId=3
I suggest using free tools to test your network device:
http://manageengine.adventnet.com/products/oputils/free-snmp-tools.html
Dec 30, 2008 | Computers & Internet
184 people viewed this question
jasbo
jasbo
