Question about Nokia N72 Cellular Phone
Hi. my phone starts automatically when i put the battery in, instead off pushing the power
Samsung Galaxy Note 4 - Stuck in a power up loop
Samsung Galaxy Note 4: power on off loop:
I have a Note 4 also.. When I updated to one of the newer OS it started power on off looping when the battery got to a low percentage. This would freak out any User. It is normal for many people however. It is a Google software firmware issue that will probably be fixed after the next patch update.
In the mean time, if when your battery gets really low and you get the power on off loop, just charge the device or pop in a charged battery.
There is no fix for this right now. You just have to deal with it.
If your battery is higher then 15% left and it is looping, then the possibility is that either you tried to/or the system automatically tried to update your phone, but the transfer was interrupted or corrupted some how.. could be bad connection between the towers or the WiFi router you were on.. or any number of other things.
If you are in the US, best to drop by a local Best Buy store. Call ahead and ask if they have a Samsung Experience Shop inside. Not all Best Buys have one.
Ask to have Best Buy transfer your call to the rep there if possible (I'm not sure if they have a phone there.. if not you may have to just visit the Best Buy store with the Samsung Experience Shop inside there..
Bring your device and your charging cables/adapter just in case, make sure the battery is charged).. Ask if the Samsung Manager can help you and when s/he will be available.
That person will have the knowledge and the equipment inside the Samsung Experience section to get your phone back to normal again, however note that you may lose all your data files on the phone. It most likely will have to be factory reset and possibly reFlashed with the OEM firmware.
WELCOME TOTHE SAMSUNGEXPERIENCE SHOP
Jan 09, 2016 | Samsung Galaxy Note 4G
Faulty battery not charged display and automatic turn off
Leo sounds like your batteries may be low on charge, you can buy a device to charge batteries out of the phone. You may want to buy one charge the battery and try again. also check the contacts on the phone and insure they are not dirty two of them monitor the battery condition. Hope this helps
Mar 18, 2014 | Cell Phones
I want to increase my Android 2.1 LG GT540 phone battery performance.
Here are some tips to increase the performance:
1) Run a lower brightness setting on your screen. Make sure it's not set to automatic. 2) Don't run widgets that update all the time. The more your data connection is running, the more power you use. 3) Make sure screen is turned off when not actually using the phone. 4) If you're in range of WiFi (like at home) use WiFi instead of cell data. It uses less power. 5) Don't have your WiFi, GPS, or Bluetooth on when you're not connected to them. It takes a lot of power for them to continuously search for a connection. 6) Run less background syncing. If you can get away with your email syncing only once every 15 minutes, do that instead of it syncing continuously. 7) Search your phone model on XDA Developers to find additional tips.
8) Last one. Don't run Automatic Task Killers. They often times shut down needed background services which requires a higher CPU load to restart. More CPU load means more battery usage.
Mar 06, 2011 | Cell Phones
My 2310 phone is not starting, battery is ok. sometime when it starts then agin shut off automatically. plshelp.
It means your set is out of order better is to alter it ... instead of wasting time on net and surfing for a solution
Jan 09, 2010 | Nokia 2310 Cellular Phone
I need to unlock my samsung u600 to any network need unlock code ?
You can get the unlock code through online sites. And provided you can get the unlock instructions from http://www.mobileunlockguide.com/
Nov 02, 2009 | Samsung SGH-U600 Cellular Phone
Same exact problem
With the battery installed, press and hold the power button down for at least 20 seconds to reset it.
check to see if the power button is stuck, pushed in...
Hope this helps!
Sep 17, 2009 | Samsung SCH-u430 Cell Phone
Battery on my HTC s710 lasts for 3-4 hours
if you momentarily push the "start" button, that should put the phone into hybernation. Which means the screen will go dark and quit using power. If the phone rings it will automatically wake up. If you want to use it just hit the start button again.
There are also some settings in the "settings" menu that determine when and for how long the screen stays illuminated when not in use.
Jul 07, 2009 | HTC S710 Smartphone
Hi there my dash phone doesnt boot up at power
try a Master Reset. But this will wipe all data from your phone. Take the battery out and put it back in again. Then Hold the two soft keys ( the two select keys to the bottom Left & Right of the screen) and then push the power button for a few seconds. The phone should prompt you to push the SEND (green) button to start a master reset.
Jun 24, 2009 | T-Mobile Dash Smartphone
White screen when turn on then it turns off
Hi, Make sure the battery is fully charged. Second try resetting the phone by removing the battery and memory cards, If it has reset button push that instead. If this doesn't work I would call your service provider.
May 11, 2009 | Nokia 7373 Cellular Phone
88 wrangler wont crank
is this a manuel or automatic transmission? if its automatic try forcing the shift lever forward while trying to start, if its a manuel check the clutch pedal switch , if no luck with those check to see if the ignition switch is giving 12volts in the start position, if not then just put a momentary contact push button on the dash and put key on power to one side of the button and the other side to the small wire on the starter then you have yourself a push button start with the key on only so there are no accidents, please rate -jeff
Sep 04, 2008 | 1988 Jeep Wrangler
Nokia N72 Cellular Phone Logo
22 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
