Question about HP Pavilion TX2000Z Tablet PC
Cheapest and best place to buy laptop motherboard
    Sergeant:
  • 244 Answers
Try newegg.com (think that's right site). do you have the skills you need to replace a motherboard in a laptop?
if not do you have a friend who's an 'electronics geek'? who can help you do it? get on HP website and look for a PDF manual for dis-assembly and replacement of various components. it can be pretty hairy!!
good luck!
Posted on Sep 24, 2009
Inner screen is crack on a kurio
Kurio 7 Screen Replacement
Written By: Eric Rice (and 6 other contributors)
Comments: 2 Favorites: 5 Completions: 12
Main guide photo
Difficulty
Moderate
Steps
12
Time Required
30 - 45 minutes
Sections
Back Panel
4 steps
Kurio 7 Motherboard Removal Guide
5 steps
Screen
3 steps
Flags
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Introduction
This is an easier part to replace than many others on the Kurio 7. Most require soldering, but this one does not. However, you must exercise extreme care when taking the device apart so that none of the soldered connections are broken. In the event that they are broken, look to our other guides for repair tips.
Tools
Buy these tools
Phillips #00 Screwdriver
$6.99
Buy
iFixit Opening Tools
$1.99
Buy
Parts
Kurio 7 Replacement Screen
Available for sale on Amazon
Buy
Step 1 Back Panel
Begin by removing the rubber cover from the Kurio 7.
Add a comment
Post comment
Step 2
Remove the four 30 mm Phillips #00 screws from the outer case.
Add a comment
Post comment
Step 3
Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
Be careful not to break off the tabs that hold the front cover and the back cover together.
Add a comment
Post comment
Step 4
Once all of the tabs are removed, the back cover should come off easily.
Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
Add a comment
Post comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Buy Now
Step 5 Kurio 7 Motherboard Removal Guide
Use a plastic credit card, or other thin object, to separate the battery from the screen.
Be sure to work the card carefully and slowly around in order to not damage, break, or deform the battery.
Carefully set the battery aside.
Add a comment
Post comment
Step 6
Use a Phillips #00 screwdriver to remove the eight 40mm screws holding the motherboard in place.
Place the screws aside in a container separate from the other size screws. You will need these later.
Add a comment
Post comment
Step 7
Place the plastic opening tool on the base of the black ribbon clip and pull up, like a lever, to release the mount. This should release the clip holding the ribbon to the mount.
Pull the ribbon out of the mount.
Add a comment
Post comment
Step 8
There should be masking tape on the yellow ribbon. Pull the tape off of the motherboard and wrap it around the yellow ribbon.
Do not pull the tape completely off the motherboard, as it is used to protect components on the ribbon.
To remove the ribbon from the mount, follow the same steps in Step 3.
Add a comment
Post comment
Step 9
Pull back the ribbons and put the battery near the bottom of the Kurio.
The motherboard is now removed so that other components can be worked on.
Add a comment
Post comment
Step 10 Screen
Flip motherboard down near base of device.
Be careful not to pull out any wires when moving the motherboard.
Add a comment
Post comment
Step 11
This is tricky, and an extra pair of hands may help. Use the opening tool to pry the screen out from underneath the tabs holding it in place.
Once you have created some space between the screen and the cover, slide the opening tool under the screen.
Slide the opening tool around the outside of the screen, releasing the tabs as you go along.
Be careful not to pull too ******* the motherboard while doing this, as there are still many wires attached to the body of the device.
Add a comment
Post comment
Step 12
You have successfully removed the screen!
Pull the screen out from the casing.
Jan 07, 2018 | Tablets & eReaders
Dropped my iPad screen now jumping how do I fix it
There are many places to get it fixed. The most expensive will be the Apple Store. You can search Yelp or other rated service sites to find the best and/or cheapest place to repair a screen in your area. It is a delicate repair, and even experienced places can get it wrong.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
Feb 14, 2015 | Apple iPad Mini
I got my Nextbook8 after having a Nook HD only last me 6 months until the battery pack expanded and i had to return it,it was replaced but I gave that to my son.So I went to Walmart 7 months ago and g
Almost everyone knows who makes the best..... Not that any brand is perfect. But people still persist in buying the cheapest. I know this doesn't help your current predicament... but you have to think before you buy! I've had 3 iPads now and none have had anything like what your describing.
Good Luck in with your future purchases.
Jan 27, 2015 | Nextbook Premium 8 Se Android
Cheapest place to buy tablet
I would suggest doing an online search. You probably will land on Amazon, which is a good vendor. I would also suggest taking a look at a Kindel, they are nice.
Dec 06, 2014 | Samsung Tab Tablets & eReaders
I HAVE A COBY 7inch. TABLET I HAD AN EXTENDED WARRENTY. I CANNOT FIND MY PAPERWORK HOW DO I FIND OUT IF MY WARENTY IS STILL EFFECTIVE?
If you had purchased extended warranty your seller would have registered this with the company which provided the warranty. If you can go to the place where you purchased the unit with the details you have provided, then they should be able to search. If your unit is faulty right now then best to take it to your local Colby repairer and they should be able to find out the details of your extended warranty.
Coby have a website but there is no support information on it.
Coby Kyros Tablets Cheapest Tablets Best Coby Kyros Tablets
Sep 23, 2014 | Tablets & eReaders
Cracked screen on nabi 2
You have to buy new for sure. The cheapest I have found is LeapTV Educational Active Video Gaming for Kids. Take a look. enjoy
Feb 11, 2013 | Nabi 2
I want to buy ipad 2 online, is it safte to do that?
Yes its completely safe to buy products online. You must keep a few things in mind :
- Must Check the products warranty information.
- Sellers refund policy.
- time taken for product delivery.
- Total shipping and handling charges (If any)
Jun 10, 2011 | Apple iPad 32 GB WiFi Tablet PC
FIND MOTHERBOARD TECRAM4S435 replaced hard drive then 3 weeks later screen will not come on tec said had short in motherbaord hardly ever used this unit not transported around at all
hey there copy and paste the following link since this site can't seem to get the hyperlink tool to work. This is for the motherboard for your model laptop at the cheapest I could find it.
http://www.getpartsonline.com/p000428380.html
Also, replacing the motherboard on a laptop is not exactly fun. Go to the link below, it is something I have come accross before. It is a step by step guide with pictures for completely disassembling your laptop which you will be doing. I suggest reading the beginning and make sure you have everything you need before starting. Good luck and let me know if there si anything else I can do for you
seth
http://www.irisvista.com/tech/laptops/ToshibaM2/tecra_M2_disassembly_1.htm
Jul 30, 2009 | Compaq Refurbished TC1000 1GHZ...
Acer Travelmate 2200 laptop
Try taking the laptop battery out. You can remove the laptop battery by turning it over, you'll usually see some sliders at the bottom, slide them to the unlock position and you should be able to wedge your battery out. The battery usually comes in a very tall and thin rectangular shape. Once the battery is out, plug the laptop in through the mains power - this may solve your problem, if it does, you'll need a new battery if you wish to use it on the move. If it does not solve your problem, it is either a faulty power adaptor, or a faulty power supply on the motherboard of your laptop. A faulty power adaptor or battery is the best case scenario, as it's the cheapest to buy a replacement (although it's still expensive - $120 worth in the UK roughly). A faulty power supply on the mainboard generally means you'll need a replacement mainboard which is totally uneconomical, especially with the labour cost to fit it professionally. If the battery and power adaptor is not faulty, you might as well scrap it and get a new laptop. Good luck Tina!
Sep 07, 2007 | Acer TravelMate 302XCi Tablet PC
HP Pavilion TX2000Z Tablet PC Logo
431 people viewed this question
Top HP Tablets & eReaders Experts
Anthony Pattay
Level 1 Expert
Lawrence Oravetz
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
