Question about JVC KS-AX4550 Car Audio Amplifier
Where is the signal wire from a jvc car radio going to amp
    President:
  • 196 Answers
Is the blue one.
Posted on Apr 27, 2010
Jvc car radio won't mute on incoming calls
I think the only hope you may have is the radio has an auto signal select in the menu somewhere. You can't use the mute wire as that will mute the AUX as well.
Dec 08, 2013 | JVC Ks-bta100 Bluetooth Adapter For Select...
My cd's wont play and my ipod but radio works on my jvc kdr 520
Are you talking about just the audio coming from cd's and ipod? If so, are you using an amplifier? If you are using an external amplifier, you may be using the blue wire (power antenna remoter turn on) instead of the blue/white wire ( amp remote turn on) to turn the amp on. The blue wire turns off when leaving tuner mode, thus turning off the amplifier.
Feb 21, 2012 | JVC Car Audio & Video
SETTING RADIO & SOUND
if you are talking about the time and stations "presets". pull the radio out and look for the yellow wire off the back of the radio make sure it is going to a hot wire."one with contentious power i hope this helps
Aug 22, 2009 | JVC KD-G310 CD Player
Can I use a Chrysler/Infinity amp with aftermarker JVC radio?
it wouldn't be advised unless there are rca connections into the amp. these are the same as the inputs in the back of the jvc. It is possible to connect into an amplifier using speaker cable but i wouldn;t advise doing this unless you know what your doing.
May 15, 2009 | Kenwood KDC-MP235 CD Player
AM NOT WORKING ON NEW CAR RADIO
are you sure you put the antenna wiring in the back of the unit all the way in? or properly?
Mar 29, 2009 | JVC Car Audio & Video
What colour are the power wires, are they green & yellow, black, black & grey, blue & grey, red & grey or black & green. I want to connect a cd/radio player but don't know what wires connect to the cd...
JVC KW-AVX800 The black wire is your ground The yellow is your positive 12v constant so connect this to the wire that has 12v when the car is off. The red connect this to the key switch wire meaning the wire will have a 12v signal only when the key is tured to the on position. The blue is for a power antenna the blue/white stripe is if you have external amps this wire goes to the amps remote on The orange/white stripe connect this wire to your cars dimmer switch Happy Wiring
Mar 21, 2009 | JVC KW-AVX800 CD Player
Trying to hook up a AMP
What I did to manualy turn on and off my amp is I put a wire hooked to the fuse followed by a switch and then from the switch ran it straight to the amp. Make sure that the wire plugged into the fuse is the on the fuse for the radio and that it is live only while key is turned on. I have this set up for police reason. They do not like loud music where I live. I have never had a problem with this set up. RADIO FUSE-------SWITCH----------------AMP
Mar 03, 2009 | JVC KD-PDR30 Car CD/ MP3 Player
On a jvc kd-g632 cd player which wire port is for a remote lead for fitting an amp
The turn on voltage that the amp needs comes from the radio wiring harness and it is the blue wire that is in between the red and the white wires on most JVC radios.
Hope this helps and a rating of "FixYa!" would be appreciated for this free information.
Let me know if you need any more help.
Dave
Jul 21, 2008 | JVC Car Audio & Video
Power Amp not working When A CD is playing
Hi Cassiel,
You have it wired wrong. The Power Antenna wire is for antenna only. When you go to something other than Radio, the antanna wire signal to turn retract the antennaor turn off your amp. you need to use the Blue wire coming out of your CD player. The intended function of the Blue is remote turn on when every the radio is turned on. This will keep you amp on as long as your Radio is turned on. Change the wires behind the radio from the Power antenna to Blue Remote wire.
Dec 04, 2007 | Sony XPLOD CDX-GT200 CD Player
JVC KS-AX4550 Car Audio Amplifier Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
