Question about Sony Ericsson K770i Purple 3G Camera mobile+256mb Cellular Phone
Camera opening problem
When camera mode is on by sliding the lens cover, a msg is displayed showing that there is another application running, close it and start the camera.To my best there is no any other application running,each time when opening the camera the same msg displays.I have even reset the settings also, but still the problem exist. what to do to overcome this problem. please help. email : sridhar.n@progen.bgrenergy.com
Raheeeeb
  • 20 Answers
SOURCE: phone camera wont open
Do formate to your phone and memory card and re install any programme. This also happend when you install trail programme and trail period is finnished..
Posted on Aug 17, 2007
SOURCE: Camera - Open Lens Cover.
The switch that looks if the lens cover is opened is broken, you will have to ask a repaircenter to replace the switch for you, as the camera won't function without it. the switch is soldered on to a flex cable, thats quite difficult to solder by yourself.
Posted on Sep 19, 2007
kroy
  • 11 Answers
SOURCE: K790i camera not working
try to visit your nearest cellfone service and tell them to reprogram your fone!!! im sure your fone has a virus!!!
Posted on Nov 05, 2008
Dipu007
  • 2110 Answers
SOURCE: w580i camera problem
Solution:1(model:W580i)
*Remove the memory stick and push the air (from mouth)into the Inner camera.After that it will work Fine.
Reason: If Dust in your camera lens, the error will appear, so it is a matter of sensor.
Solution :2
* Observe the problem little closer, and fix it, b'coz you know your mobile very well than the 3rd Person.
Solution:3
Throughout all the mails regarding that error messages using Googles Search
Don't go Mobile service stations without knowing a nature error, because they ready to cheating us. Becareful.......... Freinds
Posted on Feb 15, 2009
SOURCE: "Another application is running. Close it, then open the camera."
change upper flex(bonzer flex). 100% solve
Posted on Feb 21, 2009
My camera turns on by itself even with the slide in front in the closed position. The screen then shows the warning that the lens cover is closed. When I open and reclose the lens cover in 10 or so...
Most likely some dirt, dust, or other particle is jamming the lens opening gears. You can try to spray some compressed air into the lens assembly, hopefully dislodging whatever is obstructing the lens cover. If this doesn't work, the camera will have to be serviced, which can be expensive. If the compressed air doesn't work, and you decide to have it fixed, get an estimate first. Often the cost of repair justifies going ahead and purchasing another camera.
Good luck, thanks for using FixYa, and hope this helps!
Aug 05, 2010 | Sony Cyber-shot DSC-T77 Digital Camera
N86 camera issue
Here are the steps.
  • go to the camera application while the main camera lens is closed. (front camera will automatically be used)
  • Once camera application is up,open the camera lens. (application will switch to main camera)
  • go to video mode (you cant access image mode settings at it will crash the application)
  • go to the settings of the video mode and choose to reset the camera settings.
  • That should fix it
Feb 24, 2010 | Nokia N86 8MP Unlocked Dual-Slider 3G...
Lens Cover Error-Lens Cover will not open
You may have dust or some liquid blocking the cap from opening. Take a q t tip and clean cap. Use the q t tip to try to jar cap loose.
Jun 30, 2009 | Nikon COOLPIX S51 Digital Camera
Turns off due to sliding lens cover
may need to replace the screws in the door or even tighten them up
Dec 30, 2008 | Olympus Camedia Stylus 300 Digital Camera
Lens cover
Well, I just looked at one, it is not easy to get to the front cover. Everything is removed from the back of the camera. The display, both circuit boards and the battery compartment have to be removed first. You may do better locating another camera, eBay is always a good start.
Mar 28, 2008 | Fuji FinePix 2650 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Cybershot camera lens cover closed
Follow the steps below to troubleshoot if the lens will not open, retract, or extend. WARNING: There is a risk of hardware damage. Do not attempt to manually force the lens in or out. Doing so may damage the camera. NOTE: Because each of these steps represents a possible solution to this issue, check the camera status after completing each step. Ensure the battery is adequately charged or connect the AC power adapter (if applicable). Perform a power reset. If the camera lens is still not operating correctly after completing the troubleshooting steps suggested, service will be required. Hope this helps
Aug 23, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Lens Cover Closed
the switch inside that activates the camera is probably loose, or worse, broken.
Sep 09, 2006 | Sony DSC-T7 Digital Camera
No Image on display screen
Does the play back show any of the pictures you have taken before? are you sure the little lens cover is opening? there is a shield that closes down to keep the lens protected from debris and finger prints. Sometimes they can get jammed and not open. Tap on the front of the lens see if it opens. Switch it to auto mode if its not in auto mode.
Apr 04, 2006 | Sony Cyber-Shot DSC-F55 Digital Camera
Cover open, camera does not turn on.
Completely open lens cover by sliding the lens cover all the way to the right until you hear two clicks. The first click will put the camera into playback mode. The second click will put the camera into shooting mode.
Sep 01, 2005 | Olympus Camedia C-450 Zoom Digital Camera
Sony Ericsson K770i Purple 3G Camera mobile+256mb Cellular Phone Logo
56 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
