Question about Sony KP-65XBR10W 65" Rear Projection Television
Sony KP-65XBR10W had blinking light
I have a Sony KP-65XBR10W that had a blinking light on the front, either blnking 9 times or continuously. I replaced the fuse and it no longer blinks, but does not respond to anything. Where should I start looking? I believe the problem is on the G-board/power supply. Let me know if you can help. Thanks
  • 2 more comments
  • Tom Fillmore
    Tom Fillmore Sep 24, 2009
    I no longer have the blinking light and wanted to know whether I fixed the problem by replacing the fuse or where to go from here. I will figure out what the codes mean
  • Tom Fillmore
    Tom Fillmore Sep 25, 2009
    This information seems helpful, but if those are the locations of components I don't have any of those. It's probably not specific to my tv though. I also assume that the standby power comes from the power supply "G" board? R-resistor, Q-transistor, IC-integrated circuit, VDR-?
  • Tom Fillmore
    Tom Fillmore Sep 27, 2009
    The tv will not respond to the Self Diagnostic Code.
  • Tom Fillmore
    Tom Fillmore Oct 19, 2009
    What does the channel button look like? This is what my remote looks like. http://i265.photobucket.com/albums/ii209...
  • Sony Master
  • 5,138 Answers
In your google toolbar type in Understanding Sony Blinking codes it will then take you to website that tells you what the blinks mean .
Posted on Sep 24, 2009
  • 1 more comment
  • ladywinn
    ladywinn Sep 25, 2009
    No Blinks- Fuse,R607,Q601,IC601,R612 and VDR601
  • ladywinn
    Again Go to website Understanding Sony Blinking Codes by ecoustics.com There is tells you what you can do ,with tv off use hand unit Press display-ch-5-vol-then press power this will enable you to run a self diagnostic Mode
  • ladywinn
    ladywinn Sep 27, 2009
    If TV wasBlinking 9 times then problem on the G-Board is 2 Diodes
    D6116 and D6301 they are Fast switching Diodes NTE577. Have you gone to website yet? Call Mats they will have Parts you need!
    1-800-628-1118 Also CK at Partstore.com or Call 1-800-925-7278
    Did you with TV off On Hand unit Press( Display then, channel ,then 5, then volume minus Not the vol plus sign, then power
Sony Projection TV KP-65XBR10W 10 years old. The red light on the front blinks in intervals 5 times and the picture blinks to black at the same time some times.
You probably have one or more of the CRT's drawing too much current because of age. The only repair is to replace all the CRT's. The Main problem is the cost involved and the fact that you must send the CRT's back to sony to be rebuilt because Sony no longer sends the assembly with the optic coupler. Sony just does not support the older NTSC sets when it comes to the CRT's.
I hope this helps,
Skyassoc
Dec 08, 2010 | Televison & Video
Screen had red/orange lines, then the screen went all orange
your read crt is shorting out sorry to say the crts are no longer avail, you can have them rebult but on a projection set they will never look good due to phosforous burn I would say it is time to retire the set
Dec 11, 2009 | Sony KP-65XBR10W 65" Rear Projection...
My KP-65xbr10w appears dead no life when plugged in.
If you have no indication of power you may have lost all of the voltages to your power supply, including the 5 VDC standby voltage. I am not sure if you can get a new G board, but you should be able to get the individual components that you need. I would look for the cause of the power supply failure first, and I think I would look at your Horzontal Output Transistor. I am thinking it is Q501, Q401 or something like that. I have repaired many of these and the HOT is most likely the problem. A shorted HOT would cause the power supply fusables to blow and the entire set would appear to be dead.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Nov 28, 2009 | Sony KP-65XBR10W 65" Rear Projection...
Problem for Sony KP-57WS520 57 in. Rear Projection HDTV-Ready... Stand by light flashing, TV will not turn on
need to know the number of blinks as thats an error code. it should blink a series of blinks pause briefly then repeat the sequence.
Nov 23, 2009 | Sony KP-57WS520 57" Rear Projection...
TV will not come on. TV standby light blinks nine times continuously. TV is Sony KP-51WS520
Nine Blinks- Replace D6116 and D6301 on the "G" board, do not solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Mike
Apr 16, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony kp-65xbr10w led light blinks 5 times
i have a sony tv model kv36fs17. led flashes 5 times. tv works but no red color. would could be the problem? thanks
Jan 23, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Sony tv KP-57WS520
9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Sep 23, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-65XBR10W 65" Rear Projection Television Logo
171 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
