Question about Kenwood KDC-MP228 CD Player
Parking brake switch
Where?and what?and how?
  • 34 Answers
If you have a problem with the video only going on when you pull the hand brake just reconnect the wire going to your hand brake to earth quick and easy
craig:)
Posted on Jan 20, 2008
On Mercedes Actros 1841 (2008 year of manufacturing) parking brake light blinking (on and off) even parking brake is not applied and truck is driven. What will be problem and solution?
check for loose connections or wire grounding out near the park brake switch
as it should be air controlled spring brakes for the park brakes check for a problem air switch in the park brake air lines
Oct 21, 2016 | Mercedes-Benz Cars & Trucks
85 tercel parking brake light stays on
I am assuming you mean the red light on the dash that says "brakes".
That light is powered by the parking brake switch and the pressure switch for the hydraulic brakes. If the parking brake is on, or the brake fluid is low, the light comes on.
Dec 15, 2012 | 1985 Toyota Tercel
Parking brake warning always on
Loose park brake lever. Faulty switch. If the e-brake is on the left side floor, pull up on it and if light goes out it is loose e-brake lever. Other than that it may be faulty switch.
Apr 06, 2012 | 1993 Buick Park Avenue
Brake problem light on in dash after i used parking brake
It sounds like either you did not get the parking brake handle all the way down or the switch is stuck. If the switch sticks, sometimes it will release if you hold the button in and move the parking brake handle up and down rapidly a couple of times. If this does not work, then you will need to disassemble the center console to get to the switch and repair it.
The parking brake indicator switch is located at the base of the parking brake lever mechanism on the right side.
Sep 23, 2011 | 2002 Pontiac Grand Am
I had no problems with shifting my car into gear, but I went to it a couple days ago and would not move from Park. I tried the override to see if it would move but it still wouldn't work. Any suggestions.
The problem is in the brake switch. You have to have the brake pressed to get it out of park. When this switch goes bad then it doesn't think that the brake is being pressed. You will have to replace the switch. It is located on the top of the brake pedal up under the dash.
Oct 20, 2010 | Chrysler 300 Cars & Trucks
BRAKE LIGHT CAME ON TRAVELING DOWN THE ROAD. CAR WAS PARKED AT WORK. NOW WE CAN'T GET IT OUT OF PARK
CHECK BRAKE LIGHT SWITCH ON BRAKE PEDAL TO SEE IF SWITCH OR BRACKET CAME A LOOSE.IF NOT REPLACE BRAKE LIGHT SWITCH THEN REPLACE BRAKE LIGHT SWITCH FUSE.THE BRAKE LIGHT SWITCH COULD HAVE SHORTED OUT PLUS BLOWN FUSE IN WHICH WILL CAUSE YOU NOT TO GET CAR OUT OF PARK.
Sep 09, 2010 | 1996 Pontiac Grand Am
My jensen in dash dvd player keep asking for parking brake sequence
there's a wire from the dvd player that is supposed to be hooked up to your parking brake switch to keep you from viewing during driving. i have a pioneer unit and i ran the parking brake wire to a switch and ran another wire from the switch to ground. then when it asks for the parking brake sequence, (with my unit) i flip the switch from off to on then off then back on. this makes the dvd player think that you've applied, let go of, then applied the parking brake.
Feb 16, 2010 | Car Audio & Video
Head lights burn some time only after you press and release the park brake repeatatly whats worng
Well the headlights do not come on if the parking brake is still on. So maybe in your described case you are having a problem with the switch at the park brake. The switch is probably sticking in the "park brake applied" position. If you look at the switches at the parking brake and can spray some penetrant on them this may free them up.
Dec 06, 2009 | 1992 Chevrolet Cavalier
Kenwood KDC-MP228 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
