Question about Sport & Outdoor - Others
My big bear 350 atv back fires when you give it gas?
  • 29 Answers
HELLO; Have you worked on the quad recently? The reason I ask is you might check your valves it sounds like their to tight and your not getting enough flow, or you might have a vacume leak, that you can check with a can of carb. cleaning fluid spray around each sealing surface near your carb. then listen for a change in the rpm. GOOD LUCK......GREASY
Posted on Oct 02, 2009
Yamaha 350 big bear
Valve lash. you may just need your valves adjusted.
Oct 03, 2013 | ATVs
Yamaha big bear 350 4x4
check the gear box
Oct 02, 2013 | ATVs
Atv big bear 350 won't idle after cleaning
sounds like your mixture was leaned out because ur filter was cloged up ...making it run rich so was adjusted by screwing air screw out, now uv cleaned it, adjust it to make mixture richer by screwing back in until runs smotherly
Sep 08, 2013 | K and N Yamaha Big Bear Yfm350fw Air...
Location of the starter on a yamaha big bear 350, 1987-1993 model
did you locate the battery? now inspect the positive cable... it should lead you there. follow the cable. remove covers for access as required
Mar 26, 2013 | Grizzly Big Bear Atv Maintenance Free...
I have a 1987 yamaha big bear 350 atv. I'm trying to get the electric start working again. i knew the starter clutch was bad so i repaired that. it has a new battery and solinoid. The system wor
Jake, if your ignition is electronic, you may not have enough system voltage to run the starter and the ignition at the same time.
Try with a jump from another vehicle. Likely it will start.
Try bringing the battery to a full and complete charge, water up first,
then retest starting. Some units just have to have a perfect battery and state of charge.
Nov 02, 2012 | Motorcycles
My kolpin fourwheeler will idle, but stalls when i give it gas
hello, make sure your spark plug is getting a good blue flame, if not you may need cdi, i replaced one on my atv, would idle all day would not rev up, cdi boxes is the brain of your atv, motorcycles tells it what to do as far as firing, timing advance, hotter fire to plug etc..my atv is a 2000 350 warrior, their known to not have very reliable cdi,lots of problems with warrior cdis....
Feb 21, 2010 | 2004 Yamaha YZ 450 F
Sport & Outdoor - Others Logo
153 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
