Question about Sony Computers & Internet
Sony modal-VGN-FS980 Fn key is not working. solutions
mdsaeed67
  • 849 Answers
SOURCE: fn keys are not working
did u have the recovery cd, use it, boot from it, it will install every necessary software/op system need the computer, if not
install windows from any bootable cd, no specific drivers are come for fn keys, it will work by default, then install the device drivers one by one.
Posted on Nov 05, 2008
SOURCE: FN keys don't work on Sony VAIO VGN-SZ18GP
The solution is as follows, which worked for me:
- Install Windows 7
- let it update all the drivers that it needs to
- Install additional Sony drivers that you need (XP drivers work just fine, but make sure to install them in Administrator mode, so, Run as Administrator), such as camera, fingerprint scanner, etc
- Install the Notebook Control Device Driver (without this the other software does nothing)
- Sony Utilities DLL
- Sony Shared Library
* restart computer *
- Sony Video Shared Library
- SUS (Setting Utility Series)
- VES (VAIO Event Service)
After this one the Fn keys will start to work. The S1 and S2 keys don't work due to something to do with UAC (but I don't need them anyway)
- VAIO Control Centre (will allow you to change what the S1 and S2 keys do, even though you can't use them :) )
That's it and it worked for me.
Posted on Apr 27, 2009
SOURCE: fn key for laptop sony vaio vgn-s460p
the function keys doesnt need any extra driver.
but if you want to use tha additional features of function key like save, load, close and many more then you can get the software directly from official website of sony. alternativel you can download hotkeycontrol xp by which you can reconfigure you keyboard to add extra feature and options
Posted on Jul 06, 2009
myrlex
  • 674 Answers
SOURCE: Fn key does not work
just install the component of your sony if you dont have download it from the internet..
Posted on Sep 14, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Sony Vaio VGN FS980 laptop stuck in Boot Loop
What I usually do in this situation is remove the harddrive from the infected computer and using an IDE / SATA to USB adapter, I attach the infected harddrive to my other system, then I run malwarebytes and avast 4.8 scan, since it is attached to another computer, none of the windows files will be in use and can be scanned. Once the scans are complete and the infections cleaned, the harddrive can then be placed back into the laptop. If the computer still is having trouble booting, the boot.ini file is probably corrupt. Try the fix below, you will need to have a windows installation disc to make it work. Follow the guide closely.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Jan 21, 2010
Sir, my name is RAJ. i am use to sony vaio laptop model no VGN-FS980. sir my laptop all divers is format so pl kindly info other vise forward to all divers. Thank you.
Hi! Welcome to www.fixya.com.
You can download the all the drivers of your Sony VAIO-FS980 PC notebook. Here is the link: http://esupport.sony.com/perl/swu-list.pl?mdl=VGNFS980
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 18, 2011 | Sony VAIO VGN-FS980 Notebook
My keybord went crazy if i press spacebar this happens "\ wdfh also all the buttons so i have to use screenboard, heelp please vaio vgn fs980
Try to clean the keyboard. Sometimes the key might got struck, check for the \ key whether it is struck or not. If the problem persists you have to call Sony service center.
Jan 20, 2011 | Sony VAIO VGN-FS980 Notebook
My shift keys do not work on my sony vaio. I have a VGN-N130G. Neither shift key works, however, the CAPS LOCK works. It was fine yesterday. I did restart the computer and it did not fix the problem.
sad to say but if you want you can replace it with new one. or you can use a usb keyboard. or just let it be until some of the keys become defective. its your choice.
May 25, 2010 | Sony VAIO VGN-FS980 Notebook
My sony vaio VGN-FS980 PC Notebook wont shut down gets frozen at the windows is shuting down screen
yah i dont know waht your question is but try unplugging the power and taking out the battery or hold the power button down till it turns off
Apr 06, 2010 | Sony VAIO VGN-FS980 Notebook
Very light display
click on Fn button and press up arrow
Nov 05, 2009 | Sony VAIO VGN-FS980 Notebook
What is the driver that i can download for the video card and to make my Fn keys work?
support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB
Aug 06, 2009 | Sony VAIO VGN-FS980 Notebook
Can I run a Sony Vaio VGN-FS980 laptop closed?
You should be able to go into power management utility whether it be sony or Windows and change the "when lid is closed" option from hibernate/shutdown to "do nothing"
on XP
CP>Power Options>Power Schemes
Jun 10, 2009 | Sony VAIO VGN-FS980 Notebook
FN keys doesn't work?
download the components and install it
Jan 28, 2009 | Sony VAIO VGN-FS980 Notebook
Computers & Internet Logo
347 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
