Question about Mitsubishi WS-65819 TV
Ws-65819, No response, Not even the blinking green light
When I plug in my tv it doesn't even have the blinking light. Never had this problem before. Power cord is fine and 5 pico fuses read fine. Would the DM/Power board on the left be worth checking out, even if I don't have the green blnking light? Thanks for any help.
  • 4 more comments
  • Tom Fillmore
    Tom Fillmore Nov 03, 2009
    It looks like the previous owner tried to do some soldering. Atleast 3 traces, around 3 of the pico fuses on the circuit board, have lifted. What do I need to do to repair this board? http://i265.photobucket.com/albums/ii209... http://i265.photobucket.com/albums/ii209...
  • Tom Fillmore
  • Tom Fillmore
    Sorry for double posting.
  • Tom Fillmore
    Tom Fillmore Nov 04, 2009
    Yeah, I'll see what I can do. Thanks for the immediate response. Very much appreciated.
    Do you have any advice on Samsung DLP's? http://www.fixya.com/ThreadAsker.aspx?th...
  • Tom Fillmore
    Yeah that's where I'm stuck right now, because the color wheel is fine on both. I'm guessing the problem is on the power supply because that's where the ballast gets it's power from. Thanks again
  • SD Tech
    SD Tech May 11, 2010
    you might want to check first in the main power supply to see if you have voltages there--the DM or receiver unit gets its power from the main power supply indirectly
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
To repair damage--you understand the foil at each connection is copper---you have to scrape some of the green coating off near the parts and solder the exposed foil---idea is to solder a wire across any gaps to complete the circuit.
Got it?
SD TECH
Posted on Nov 03, 2009
  • SD Tech
    SD Tech Nov 04, 2009
    as far as the other set goes----remove lamp and take a good look at the color wheel--it faces the lamp and if it is shattered or missing parts of the plastic wheel---lamp will not come on.
    SD TECH
WHAT IS WRONG WITH MITSUBISHI TV MODEL WS65819 THAT POPS ON AND OFF?
shutdown is happening= If set has been unplugged plug it back in and turn set on--when green power light goes off in a few seconds:
On front of set (not the remote) press and hold both the Menu and Input (Device) buttons at same time and hold for at least 5 seconds---then release both.
Power light will blink an error code like 2 blinks, 2 blinks pause and repeat it for a total of 5 times.
Let me know what error code is and I will tell you what it means.
SD TECH
Apr 26, 2012 | Mitsubishi WS-65819 TV
WS-65819 Shuts off
Yes, remove front speaker grill (pulls off) and inspection plate behind it.
There are 3 large circuit boards as you look from the front---signal to the right, power to the left and Deflection (vertical and Horizontal) in the middle.
What you want to look for is on the middle board any sign of GLYCOL which sometimes leaks from the picture tubes above it.
It is a clear liquid and even tiny amounts can short or stop the board from working; most damage should be in first 3 inches from front of the board----if you find any DO NOT TOUCH IT as it is toxic.
Glycol damage is not uncommon and the first thing you want to look for.
Jan 26, 2012 | Mitsubishi WS-65819 TV
Front panel light just blinks
Hi Sharon,
Blinking of the LED at the front panel has an equivalent error code to give an idea what's going wrong to the set. Please check if there's a pattern of blinks, number of blinks separated with a pause or if the led blinks green continuously.
Jdvillanueva
Jan 05, 2012 | Mitsubishi WS-65819 TV
Mitsubishi ws 65819
Ur power board ic converter it dead.
Ur Convergence board is bad going to die to.
Both must change.
Aug 15, 2009 | Mitsubishi WS-65819 TV
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi 65819
2-1 means no errors, what is it doing or not doing?
May 15, 2008 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 Sender Board problem
yes it can the cost is $350 sumwut dollars ,i got my tv for $54 and thats wut was wrong with it ,the board that is connected to your power cord is wut needs to be replaced sears can do the job but the labor is $200
Nov 30, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 TV Logo
262 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
