Question about JVC AV-27530 27" TV
Our TV screen shows a black band on top and bottom in the panorama setting! How can I get the 16:9 setting without those black bands?
3 Suggested Answers
BMW Rider
  • 232 Answers
SOURCE: JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Posted on Dec 20, 2007
SOURCE: JVC TV - BLACK HORIZONAL LINE ACROSS THE TOP OF TV
The vertical circuit is not pulling the top of the picture to the top of the screen (CRT) correctly. Its possible you have a loose wire or device ( after moving ) . If you have vertical agustments on the back , you may be able to adjust the picture taller; if the picture becomes stretched ( non - linear ) then you definately have tv tech only problems. At that point I'd really think twice about a repair and consider a new DTV or HDTV set. If the unit was damaged by a mover , then you may have a claim against them .
Posted on Apr 30, 2008
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
How do I make the picture bigger so it fills the screen and not have black bands at top and bottom
Banding of the screen usually means that the aspect ratio of the broadcast is different than the screen size ratio. Most modern TVs are 16:9 ratio. Most modern TV broadcasts and movies are as well. In those cases, when in HD mode, you will see the picture fill the entire screen. Older broadcasts and many syndicated reruns are in the old 4:3 format and will be banded. Also, some movies are in larger formats than 16:9 and will reduce in size in order to get the entire picture on the screen. That being said, most TVs DO have a stretch and.or zoom feature that will expand all images to full screen size. Be advised that this can result is image distortion, especially of the 4:3 ration broadcasts. Others will have some of the picture cut off and you may see some items such as network logos, etc. partially chopped off in this mode.
Mar 13, 2015 | Televison & Video
Disney princess tv suddenly narrowed the visible part of the screen. Now everything is squished into a two in wide band with all the rest of the screen is black.
if that 2 band according to you from top to bottom,it has a defective vertical stage.if this two band appears one on top and one at the bottom,it`s on vertical stage.leaky capacitors,resistance changed or resistor devalued ang ic`s, are too weak to amplify a signal to make the screen complete....
Jan 29, 2014 | Disney 13" TV
Black box on screen
Without a picture of it it's hard to say what you mean. Sometimes on a CRT TV the vertical scan doesn't fill the screen, but that would cause a black band both top and bottom. The usual cause is a capacitor drying out. But only a qualified tech should look into that.
Jan 04, 2014 | Philips Magnavox TS3260C 32" TV
How do I remove the black band on the top and bottom of my tv
If you have cable or dish network, They make the program fit better to your TV. If you have a HDTV 16;9 ratio you will get that too.(black bands) It's the way the companies send the info to your TV. You can change the aspect ratio on your TV's settings. (full screen). Hope that helps.
Jun 02, 2013 | Televison & Video
Hi. I have a LG LD 460. How can i view movie video using full screen of 42 inch from the USB. what i mean is what is the size of the video file in width x height which when run from usb will use...
Hi!
you can convert the video to one of this sizes (1920x1080 or 1280x720) and it must fit exactly to your screen.
If the video is not panoramic (16:9 or 16:10), you may have to crop it to fit on the given screen sizes.
Hope this helps.
Mar 05, 2011 | Video Cameras
The bottom of the screen is black-as though there is a border along the bottom. I can't find a horrizontal adjustment anywhere.
It is a vertical issue, not horizontal.
Is the picture you have complete? Is there a black band along the top as well? If so, it may be because you are providing an HD aspect ratio of 16:9 instead of the TV native 4:3.
Try hooking up a VCR and watching a tape. Do you still have the black band on the bottom?
Aug 18, 2009 | Toshiba 36A40 36" TV
Black frame around picture
Toggle through the "Picture Format" settings from your tv remote.
Flip through cinema mode, too standard....etc
Jun 12, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I can't get a full screen picture black band across top and botto
try adjusting the aspect ratio. on widescreen movies or shows you will still get the black bands on the top and bottom. if you play with the aspect ratio you can sometimes get rid of it
Apr 19, 2009 | Protron PLTV3250 32 in. LCD Television
2" black bands top and bottom
well you should clarify more but i am assuming that your tv is set on widescreen mode and the only way to get rid of the bands is by using the menus to switch your screen format
Jan 19, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
JVC AV-27530 27" TV Logo
498 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
