Question about IBM ThinkPad T30 2366 Notebook
Wirless internet not working
I have a Thinkpad T30 and the wirless is connected but I can not get on the internet. I can get on the internes using a cable connection though.
  • 2 more comments
  • nairb41 Dec 17, 2007
    I am not sure what you are saying in the first part about not having the router connected to the ISP provider hardeware.
    I tried typing the ipconfig / all at the command prompt as well as the ping and as well at the command prompt and it did not work. It said something to the effect that it is not recognized.
    I heard there was a wirless key on laptops and if your press the fn key along with this wirless key it switches the wirless on. Is this true?
    Thanks for your help
    microsoft xp professional. The internet works when it is connected to the router by wire but not when it is wireless. The router has 4 ports as is a Network Everywhere Wireless B broad band router NWR11B.
    16V 4.5A
    I do not have a wireless card on the outside.
    ipconfig /all error says: ipconfig is not recognized as an internal or external command, operable program or batch file.
    ping says: ping is not recognized as an internal or external command, operable program or batch file.
  • Anonymous Dec 29, 2007
    I can pickkup the router signal very strong but cannot get on the internete
The ipconfig/all works now. So I am not sure what the next step is. It gives a list of info that I am not sure what to do with,
Posted on Dec 23, 2007
  • 556 Answers
If the router has a block of 4 ports (or more) on the back and one is not used yes -- the separate port which may or may not be connected to the Internet Service Provider's equipment cannot be used for this purpose. There is only one connection point on your computer.
Any connection requires
a unique IP address on the correct Subnet
the appropriate subnet mask for the network segment
the appropriate default gateway for the subnet
and one or more DNS addresses so names like can be accessed
the following work on both the wired and wireless adapter
this can be checked from a command prompt window using the command -
ipconfig /all
A second command can be used to determine of the network adapter is communicating with the router the command is
ping (default gateway)
where (default gateway) is replaced by the default gateway
returned by the ipconfig command above
could be or something close in a home network.
4 timeout messages indicate failure and 4 message with elapsed time in ms (milliseconds) is success. the results can be mixed, but should not be in this case.
If you need additional instructions to issue these commands ask in a reply to this message and I will send you the detailed instrictions.
Record information returned by the above tests and return in a comment with the current problem description and I will respond with additional steps and questions or possibly a solution.
Posted on Dec 16, 2007
  • 1 more comment
  • david Dec 17, 2007
    What operating system is your T30 running?
    Does your T30 work when connected by wire to the router or is it connected to something else?
    If something else turn it over and see if it has a manufacturer name and model number? tell me what it says;
    Thanks we will probably do more next time but this is enough for now.
    On a label on your T30 is there a set of numbers 2366 followed by three letters and/or numbers -- maybe with a dash between -- if so what is it?
    IF you have a separate wireless adapter card --
    What is the manufacturer and model of the wireless adapter?
    Back to your wired PC
    Open command prompt like before
    Issue the command
    (contains 13 characters overall with one space)
    ipconfig /all
    copy what its says and send it to me even if it is an error.
    also try
    You are doing great so far -- a few more messages and we should finish this.
    get 2366-??? number
    See how with link click on Thinkpad and 3000 family notebooks
    download and install these and run them wired and wireless
    ipconfig from start menu just like on the page
    Ping from start menu as BePing enter address and click ping
I am unable to find netgear connection on my ibm thinkpad t30
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Feb 14, 2011 | IBM ThinkPad T30 2366 Notebook
I want to connect my Thinkpad T30 laptop to HDTV
Depends on what connections are on your laptop and tv check them both. If you have a HDMI port on both you can use that. If not most recent TV's have a VGA port which you can use using a standard vga cable if not they will have a DVI or S-Video port and you will need one of those cables which are all availble from any computer shop. But check which one you need first
Feb 22, 2010 | IBM ThinkPad T30 2366 Notebook
Where do i find the wireless lan button to turn on the wireess picks up a connection piont but lan not on ... IBM thinkpad t-30 type 2366
This can be done in one of 2 ways
1) there may be a wirless button on your laptop, generally on the front or on the side simply slide this in the opposite direction
2) press the FN key and the key with a radio mast type symbol or sattelite type symbol on there with the IBM's generally it is F5
Please leave feedback/vote if this has been useful
Feb 10, 2010 | IBM ThinkPad T30 2366 Notebook
We can't get our IBM T30 to connect with our Linksys router . The computer has a 3com wireless card
Has the Wireless card ever worked attached to another wireless router?
Is the card an internal miniPCI card, and is it an official IBM card for your region? Thinkpads check whether the card is for the correct region before configuring them in the Windows drivers.
Are you using the Thinkpad Assistant Wireless tool. I have found that it appears to be impossible to configure this software for 64 bit WEP or WPA PSK authentication.
Sep 11, 2009 | IBM ThinkPad T30 2366 Notebook
Wifi on ibm thinkpad t30
The wireless driver may got corrupted or uninstalled.
Go to Control Panel - System - Hardware - Device Manager - Click on Network Adapters and if the wireless card is listed click on it to see if it is working and enabled. If not then reinstall the wireless driver.
Aug 13, 2009 | IBM ThinkPad T30 Motherboard 91P7695 -...
Try checking your network configurations. Set it to automatically obtain network address of your using DHCP.
Jun 26, 2009 | IBM ThinkPad T30 2366 Notebook
Need wireless connection driver
it should be on your recovery disk that came with computer when it was bought new if you dont have that disk try windows update to fine it
Mar 26, 2009 | IBM Thinkpad T30 Notebook
Ibm thinkpad t30 will not start
You should charge the battery longer about four hours. Then the light should be green. Try. If that don't work disconnect the battery and check for anything. Connect your battery again and take a look. If it still isn't functioning please let me know.
Dec 25, 2008 | IBM ThinkPad T30 2366 Notebook
Psp dns failure
How is the machine connected to the Internet? Modem, cable or ADSL? Or are you using it at work through a company network?
Jan 06, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
206 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
