Question about DKNY Watches
The small screw has come out of the bracelate and no one seems able to fix it
    Sniper:
  • 59 Answers
I guess it customize bracelet and so do there pins & screw
company does that so consumers bound to send them to fix
well if you in chicago we can try our best to fix it or take to any expert watch maker who can find substitute
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Posted on Sep 24, 2009
How to remove the movement from a seamaster 1342
Here is a video that will help you ,if theres no screw it will be a small button that you press bown on then pull crown out,,
Mar 26, 2013 | Watches
How to remove links from invicta sea spider polyurethane bracelet
You should use two extremely small flat head screw drivers to remove links on Invicta polyurethane watch bands. The smaller pens on the polyurethane watch bands have a notched cap (tiny screws) on each end .You must use one screw driver to hold the pen cap (screw) steady and the other screw driver to turn the cap (screw) counter clockwise. You only have to remove one notched cap (screw). These caps (screws) are very small and you should be careful not to lose them. Once you removed the cap (screws) you can use a small screw driver or paper clip to push the pens through the links. You should repeat this til you remove the desired links.
Nov 24, 2011 | Invicta Sea Spider Chronograph...
The word (op en) on the top in place of the date or the day and nothing is responding
I had this problem and managed to fix it. There is a small metal plate locate inside the back cover of the phone that can be knocked out of position. The small plate should be in contact with the two screws in the top right hand side of the watch (when back plate is off).
To remove back plate you must remove the strap. To do this you must remove the four pins that connect the strap to the watch body. Take out the pins and set aside. The two plastic inserts can now be removed.
Remove the four screws and remove the back plate. Be careful not to lose screws, rubber seal and small plate.
Reglue the small plate to back plate and allow to set.
Reassemble watch in reverse order and watch should work as normal.
Good luck
Feb 27, 2011 | Casio Protrek Triple Sensor PRG70 1BVDR...
How do i remove the back on my sekonda mens watch
mcdevito75 here, Generally thr back is simply pryed off useing a sharp knife (steak) or with a case opener, or at times the back is screwed on, little square holes around the back of the watch require a special tool, or there may be 4 screws holding down the back to the case, even if you get the back off you may need Jewelers screwdrivers to remove / replace the battery. BEST BET, look for a small watch repair shop in your area.
Jul 12, 2010 | Watches
I cant seem to get the back of the watch off. How do i change the battery in my Columbia watch.
Remove the back cover.
On some watches, the cover will pry off using a very small flat-bladed screwdriver or will have screws holding the cover on. On other brands the entire cover will unscrew. Examine the edge of the back cover. If there is one small depression along the edge of the cover then the cover will pry off. If there are screws present, the cover will lift off after the screws are removed. If the cover has a raised edge with flat edges opposite one another then the cover will unscrew.
Mar 25, 2010 | Columbia Elkhorn Light-Up Watch - Large
Size 377 battery wont go in - need to unscew something?
I presume that a 377 battery is the same number as what came out. Sometimes there is a small piece of metal that is a strap that helps hold the batter in. Usually, then there is a very small screw that you have to loosen to remove the plate or just move it a bit to get the battery in. Be sure that the battery is not upside down from the way that the original was placed in. Also when putting in a new battery be sure that you don't use metal tweezers to hold the battery as it will short the battery and discharge it. Use your fingers or plastic tweezers.
Oct 30, 2009 | Kenneth Cole KC1104 Wrist Watch
How do you replace the watch band on a casio g-shock
The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
Band = Strap
You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
Jul 20, 2008 | Casio Watches
Luminox 3000/3900
I just fixed the same problem .There is a small arrow pointing to a small hole .insert a very thin screw driver or a pin and the stem will come out easily.
Jun 21, 2008 | Navy Seal Luminox Dive Watch
Casio G Shock (Model G2300)
you have to remove the pins located under the band
Feb 26, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
177 people viewed this question
Top DKNY Watches Experts
Ansel Alberto
Ansel Alberto
richie46
Are you a DKNY Watch Expert? Answer questions, earn points and help others
