Will not turn on - blue standby light is on - Televison & Video
  • 1 more comment
  • DaveMaple Sep 24, 2009
    Beko NR 21K129
    The television does not have a seperate power board - can you suggest which component may have failed - is it a common failure for this television?
    Very helpful thank you.
  • 19,396 Answers
The TV does not turn on, and the light stays on because protection circuit has started.
This is not a common problem, it is a fault state, and can be related to any kind of problem.
The protection circuit is started when a wrong voltage is detected. This can be caused by many different faults.
The first thing to do is leaving the set unplugged for a couple of hours. This will drain power completely and can reset protection if there is no real fault (eg. problems caused by power surge, or temporarily wrong voltage).
If TV is still in standby when you restart, with blue light on, then there is an internal fault.
In that case we take apart the TV and start testing the parts.
The first part being tested is the power board. A power board is an internal PSU unit. When it is external it is called power adapter or DC adapter. The essential difference is that an external DC adapter supplies only one DC voltage line, while the internal power board has lines at different voltages that are going to different boards and parts inside TV.
On power board, first test is a visual inspection, looking for bulged or leaking capacitors, or burnt areas. After that the technician will use a multimeter to read voltages and test components. If there is nothing in there, being this model a CRT, next common faults concern flyback converter. This is an high voltage part, first test is done looking for bad solder joint, and then reading voltages and testing contacts. After that the repairman will check vertical and horizontal aligment circuits. Convergence chips (reading ohms on the resistors at the base of STKs (convergence ICs), etc. If no common fault is found then we grab the service manual and test the chips on digital board and faults that are less common.
Many of this test are dangerous if not performed by a trained repairman. The TV must be left uinplugged for several hours to allow capacitors to discharge before servicing.
That is what must be done.
I think I have told you whatever I could from here. I am a technician specialized on LCD, but I also do CRT. I think I have done what I could from here.
Please do not forget to rate the solution appropriately.
Many thanks.
G.
Posted on Sep 24, 2009
    President:
  • 1,462 Answers
May i have your TV make and model number to provide assistance , please
Leave it as comment, and we will help you..
  • Vinod Kumar
    Vinod Kumar Sep 24, 2009
    HI,
    If standby light is ON in benk, it states that the power board has failed and you need to replace it
    Before confirming it, Perform a power drain once, by the following way:
    Unplug the product's power cable so the device is not grounded to the house, Press and HOLD the product's own power button for 1 minute to drain the capacitors, Plug the product back into a wall outlet and try to turn it on.
    If your TV doent come on after doing power drain, Ur power board is dead.U need a new one to replace it
    Please leave me comment, if you still need furthur assistance
    RNJ VINOD KUMAR
My Baird jo47 won't turn on and the standby red is flashing with sound what is the problem
My baird JO47 tv is stuck on standby - Digital TV - Streaming ...
www.tomsguide.com/forum/55998-4-baird-jo47-stuck-standby
Dec 17, 2012 - 4 posts - ‎2 authors
My Baird JO47 tv is stuck on standby and won't come off. ... I have a panasonic 50" TV it will not turn on no green light or standby red light ... Forum; my tv standby light keeps flashing blue on and off and won't switch on Forum ...
Baird JO47 Stuck on Standby ' Electronics Forum (Circuits ...
Dec 15, 2015 | Televison & Video
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
When I turn off my Luxor TV in the bedroom the standby light flashes blue then orange. The lights are very bright & I have to get out of bed to switch off at the wall socket. What is the problem and...
The alternating blue orange light means you have put a reminder on for a program that hasnt started before you switched off, you need to remove the reminder before you turn the tv off then the light will be steady blue
Sep 14, 2011 | Audio Players & Recorders
Technika lcd32-207 is stuck in standby. Blue standby light dims.
Hi brendafoud, have you had this fixed as mine is the same and has been for months. It happened just after the warranty had ran out(typical). Bought from ebay and the people I got it from are not very helpfull. Have you got yours fixed yet?
Jul 09, 2009 | Televison & Video
Same Problem As Well
microcontroller needs to be changed
Jul 07, 2009 | Harman Kardon AVR 7300 Receiver
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
