Question about Zanussi WJD1667W Front Load Washer / Dryer
Why can i not get the dryer to work? error E20 is flashing.
    President:
  • 267 Answers
HI,
Can you hear the pump trying to drain it when you start a cycle? If not it needs a new pump.
Is there a block in the drainage pipe (blow down it and see if it bubbles in the filter compartment). Or a block in the drain - try pouring some water down in.
Otherwise, I had the same problem (an E20 but a clean filter, no blockage and working pump) and it turned out the condenser (a large plastic vessel) or the right side of the machie (you have to take the whole back off) was full of fluff. The engineer just used a wire hanger and ran it under water to clean it out.
If you've found that it hasn't been drying the clothes fully recently that could well be the problem.
Posted on Sep 24, 2009
E20 errorcode
Sorry but with no Make we can no assist .try Google Make/model/error code
Sep 08, 2015 | Dryers
Error code E20 on a AEG washer dryer
Ok if its only bring the E20 up on the drying side then this will be a blocked dryer condenser chamber.
To get at this you need to take the back half of the washer off and from there you will see a big plastic chamber going from the bottom up to the top.
Take this chamber off and give it a good clean out with a hose pipe.
Once this is clear refit it and the dryer should be back to normal from there.
Oct 14, 2012 | Washing Machines
My Zanussi Jetsystem Timeline washer/dryer starts its wash cycle, but when it comes to draining, it wont drain and flashes E20.
Have you taken the filter out at the front of the washer and cleaned it. Mine wouldn't drain but once I did that it worked ok.
Mar 04, 2011 | Zanussi ZWD1680W Front Load Washer / Dryer
Tumble dryer works for 10 mins then switches off and flashes E20....what does this mean?
E20 relates to a blockage in the pump check the filter and that the pump is free to turn there may also be aproblem on the drain pipe check this also
Apr 25, 2010 | Zanussi FJD1666W Front Load Washer
E20 code. Not draining
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Jun 06, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WJD1667W Front Load Washer / Dryer Logo
239 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
