How long a complete washing cycle last. Mine lasts for
How long a complete washing cycle last. Mine lasts for 1 hour .
is it possible to reduce
  • 832 Answers
If you have a timer in your washing machine, you can adjust it to a lower setting, and still have a complete
a complete washing cycle.
Posted on Sep 24, 2009
Reduce time
you won't
most washers take an hour to wash a load
if you have a setting for low water and a light wash ,you might it down to 40 minutes
Jul 13, 2016 | Washing Machines
Zanussi progress 1200
check the filter for blockages
May 01, 2014 | Washing Machines
I have a Bosch Exxcel front loading washer dryer and can't remove the detergent drawer to clean it, plus all washing cycles take well in excess of 2 1/2 hours to complete. Annoying
Normal wash loads do not take over one hour, but you have to set them on clean any stain option and it will take 107 minutes to wash.
It sounds to me like your washer needs servicing by a trained Bosch serviceman, because it should not do this.
Jun 26, 2017 | Bosch Washing Machines
Whirlpool Dryer Short Cycling
Hi, there. We do not offer technical assistance, but we can help in other ways. Below are links to our use and care guides, parts list, troubleshooting, and service. We hope this can help.
http://bit.ly/112Lu7q
http://bit.ly/zkfnZd
http://bit.ly/yLv4Z5
Oct 26, 2013 | Dryers
I have a frigidaire FMB1100RHMO and first i was having a water problem and then i got the clog out. I have water pressure now but now it get stuck in the wash mode and dont come out unless i cancel it....
Hello Theresa Norman-Ramirez - Typically, it is normal for the dishwasher to delay the cycle and depending on the cycle and options selected, the cycle may last up to 4 hours. To reduce cycle time, turn on the hot water at the sink and allow it to get as hot as possible (between 120 F-130 F), then start the dishwasher. If the dishwasher cycle runs longer than 4 hours the main control board may need replacing. I would suggest contacting an experienced service technician to determine the precise cause.
Apr 05, 2013 | Frigidaire FDB1100RHM Builtin Dishwasher
Run cycle goes for 2 hrs or more
In the last ten years the machines have been using a water heat feature. The water will heat roughly 1 degree a minute so depending on the installation and temperature of the incoming water, a complete cycle can be 90 min to over 4 hours.
Eric
Jan 12, 2010 | Kenmore Dishwashers
LG Viewty battery discharges quickly .....
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Jul 19, 2009 | LG KU990 Viewty
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Prolonged washer cycle time
Hi! I'm not familiar with this model, but it sounds to me like there is not a problem! If you set the delay time to 0H, switch off the unit at the main switch, then switch back on. If there is still a 2H displayed, it means that the PROGRAM that you have selected will take 2hours! This is fairly common for the Bosch units on the 50 - 65degC cycles...some models have a "reduced washing time" button - it looks similar to the "delay" symbol, but once pressed, it reduces the washing time by almost half (cuts on rinse cycles) If your model does not have a reduced time button, select a shorter cycle (35/40/50eco), and see if the time is less. Remember that the latest dishwashers are engineered to be more energy efficient and water wise, so they had to lengthen the wash cycles in order to get good wash results! Hope this helps! C.
Jun 24, 2007 | Bosch SHU5307UC Built-in Dishwasher
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
