Question about HP LaserJet 3055 All-In-One Printer
In my printer one problem is occur like scanner error 6 turn off then on
    Sergeant:
  • 191 Answers
Please this problem is the unstoll the printer and driver and restsrt the pc
and add a printer and instoll a driver cd and select to printer select and
take a seanner and printer is ok.
Posted on Sep 24, 2009
Show error 52.00
52.X PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Apr 16, 2016 | HP LaserJet 4350n Printer
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Printer TX550W has message "A printer error has occurred. Turn off and then on. See your documentation".
Hi, this error message usually caused by jammed papers or foreign objects inside your printer. To resolve this issue, please try the following steps.
1. Turn off the printer.2. Open the scanner unit.3. Check for any jammed papers or foreign objects then remove it.4. Check the ink cartridges and lids if push down fully.5. Close the scanner unit.6. Turn on the printer.
If the same error reappears, try the following.
1. Turn off the printer.2. Open the scanner unit.3. Remove all the ink cartridges.4. Turn on the printer >> your printer will display install ink cartridges.5. Install all the ink cartridges, make sure it clicks into place and also the lids should be push down fully.5. Close the scanner unit.6. Press the Start or OK button to charge the cartridges.
If the issue persists, your unit will require service. Please contact Epson so they can check if your printer is still under warranty or ask them for the nearest service center in your area.
Nov 23, 2011 | Epson Stylus Multifunction Inkjet Printer/...
...scanner unit error. Turn off
scanner need to change.............
Aug 16, 2011 | Canon LASER SHOT LBP-2900 Printer
Jul 29, 2011 | Canon LASER SHOT LBP-2900 Printer
Everytime I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your...
when I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your documentation". Then all the lights start flashing, And then I cant do anything, but turn the printer off.
I have turned it off and unplugged it and tryed again always same result.
bdl12920@aol.com
May 10, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Says "scanner error 6 turn
If power cycling the printer didn't get rid of the "scanner error 6", you are going to have to get the AIO scanning assembly replaced. That is the top of the printer, the flat bed scanning assembly.
Apr 16, 2011 | HP LaserJet 3055 All-In-One Printer
Scanner error message hp laserjet 3030
my hp 3030 printers shows warning up bulb and make noise how can i solve it ?
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
Scanner error 6
in my network i have hp M1005 printer always i'm getting this msg "scanner error 6 turn off
then turn on"
when i make turn off and turn on again same msg comming
how can i solve this problem...
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Dec 20, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
Seeker5211
Seeker5211
