Question about Whirlpool Duet GHW9150P Front Load Washer
F11 cycle fails to complete F11 code appears
  • 6 more comments
  • Anonymous Dec 17, 2007
    f-11 appears and door will not unlock and unit has to be unplugged to reset, it is happening more and more
  • Anonymous Dec 20, 2007
    Started out as DL error - then went to F11 problem - already changed the door lock if you unplug it will start cycle over from begining.
    Same problem, starts out as DL then goes to F11.....have tried restarting the cycle but load of white clothes that was in it ended up with black all over it....service tech says there's nothing wrong and the black was from the rubber
  • hate duet Dec 20, 2007
    duet sucks should of spent a lot les $ and got a good old washer
  • debsman Dec 29, 2007
    same problem and to much freakin money for it thats what sucks you spend that kind of money you would think the crap would last longer than 3.5 years
  • Anonymous Jul 23, 2008
    F/DL and F11 errors on 3 1/2 year old washer, and this is a replacement washer for one that failed the first week I bought it. Spent too much, should have bought a regular washer at 1/3 the price!
  • Anonymous May 10, 2009
    Same thing, washer is also three years old
    Novelist:
  • 99 Answers
I have the same F11 and had the same FdL codes. From my troubleshooting I've discovered that the main circuit board has what's called "cold solder joints" at the board connectors for both the input power and the connection to the door lock and main motor. (Cold solder joints are caused when the solder temp is not hot enough or the circuit board is moved too fast through the soldering process. In this case the solder was the correct temp for the smaller joints but not for the larger connections) After touching up the solder connections on the board the FdL code went away but I'm still plagged with hit or miss F11 codes. Shaking the machine causes the F11 to go away, so it is clear to me that there is still a bad solder joint or bad connection at the main circuit board. I also replaced the connectors for the connections mentioned above because the originals are too wimpy.
Posted on Oct 16, 2010
My stupid duet washer flashes an F 26 code, when this happens it's totaly out of commission until we call a repair person to come and reset it. Does anyone know the process to remove this code so I can finish doing my laundry. Also as a side note, this code is not listed anywhere in the manual nor on any sites. Could I be the only person having this code?
Help please.
Thanks
Posted on Dec 29, 2007
Closedoor
Posted on Dec 17, 2007
  • hhappy Dec 17, 2007
    make f11 conplete
Cycle will not spin and drain properly near end of cycle. Keep getting F11 fail codes when I try resetting my kenmore elite HE 3t any suggestions?
Hi Shaun, I just found (and watched!) a good youtube video which may help with your problem regarding the F11 code, link follows below.
Trust this helps, best regards Alan
Troubleshooting and Repairing the F11 Error Code in Whirlpool Duet Washer
Feb 12, 2015 | Kenmore Washing Machines
Whirlpool awo 9663 wont start cycle
This can be due to failure of motor components or the control panel as there is no communication for the drive . Check the motor to panel wiring, check the panel for failed component
Jul 05, 2012 | Whirlpool Washing Machines
Washer code F11??? I have a Kenmore Elite front loader
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
Service manual and more HERE
Aug 22, 2011 | Kenmore Washing Machines
Will not complete cycle..shows F11. This has been an ongoing problem, cannot get anyone to fix. What would you recommend? Would like to tell the world not to buy!
The F11 error code indicates a serial communication problem between the central control board and the motor control board. This can be caused by:
  • A loose or failed wire harness connection between the central control board and the motor control board.
  • A bad wire harness connection between the motor control board and the drive motor.
  • A failed drive motor.
  • A defective motor control board.
  • A failure in the central control board.
Jan 23, 2011 | KitchenAid KHWS01PMT Front Load Washer
Stops on spin cycle and gives a f11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Hi. Whirlpool washer (Duet front load) GETS F11 error code. Any ideas as to the cause and repair?
Pull off bottom panel, there should be a schematic and trouble shooting guide to help you through any questions about you fault code.
Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting F11 code r8ght after starting,then flashes and stops
usually if this is a kenmore frontloader f11 is a communication error between the door lock and the ccu board. usually you'll hear a clicking sound before it fails. If so you need a central electric board. It is located directly under the top lid in the back. you can't miss it it's the only thing that has a lot of wires going to it.
Jan 02, 2009 | Kenmore Elite 45986 Front Load Washer
F11 Code
Plug off the wall. Shaking & vibration of your washer causes circuit board connections to become loose; due to faulty manufacture. Remove the 3 or 4 screws from the back & take off the top cover to secure the connections, make sure they are tight. This applies for the F11 & F dl codes. Dont forget to rate me &, merry xmas!
Dec 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
694 people viewed this question
Dan Webster
Dan Webster
Sal De
