Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
Our pump continuously cycles everytime we flush
Our pump continuously cycles when the water is on during the duration of our shower. It seems to cycle everytime we flush the toilet once or run some dish water. I did a test with our outside hose and we get approx. 3gal/min. The pump is a 2 stage 3/4 hp and the horizontal tank size is 20gal.
  • 54 Answers
You have a water logged pressure tank. Replace
Posted on Sep 26, 2009
Loss of hot water during shower with an electric tankless water heater.
You are using the hot water at a faster rate than your tankless unit can provide. Either get a more powerful unit or reduce the amount of water flow thru the unit during the duration of shower.
Jun 20, 2017 | Jet Home
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
I have a Maytag Performance series washer. Model MTW5740TQ0. It agitates during Wash cycle, but will not spin during after the Rinse cycle. It does this more times (95%) than not, but not everytime.
It may be falsely sensing water in the tub. Do you hear the pump running after the rinse (trying to pump out water that isn't there)? This would indicate a fault in the water level sensor. Does it seem to sense the water level correctly after the wash cycle? It could also be a timer problem.
Feb 01, 2017 | Maytag Washing Machines
Hoover 700lb
Failure of the valve in the cold water inlet section., Remove and clean, back flush with high pressure and if there is no result you must replace. Check the valve winding to confirm if the coil /solenoid is working.
Apr 03, 2014 | Washing Machines
During the dry cycle, it seems as if water is continuing to be added. A few times i minute, at least 5 cups of water is pumped out into the drain. This continues for the 3 hr dry cycle. When done the...
could be one of your water solonoid valves is leaking by, where hot and cold hoses hook up in back, they get energized when calling for water then shut down when fill level is reached, some valves have filter in it, both valves come apart and can be cleaned, make sure no debri is caught in valves to prevent from closing fully
Oct 18, 2013 | Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
I have a problem with my Asko D3350 Dishwasher, can you help? On startup the diswasher does its normal cycle and pumps excess water out and then fills the dishwasher with water to the correct level of...
Hi Tony,
I have the same machine (D3350) and almost the same problem.
Mine starts each cycle fine - pumps out - fills - rinses - pumps out tht first load and then does not fill again. If I manually fill with a bottle (about 2 litres) for each subsequent cycle then it washes as well as it ever did.
Seeing it fills once it cannot be the water supply, nor the solenoid that operate the water supply. So, my guess is the control panel.
Like you I would love to simply take advantage of the PC Upgradeable featurewshich seemed so attractive at the time of pruchase.
Jason
Dec 31, 2010 | Asko Dishwashers
The dishwasher seems to be cycling - but I no longer get the flush into my disposal and I don't hear much water circulating inside the machine. Also, the soap doesn't all diappear. Any suggestions?
The high pressure water pump is defective and is not spraying the much required jets of water to the dishes.
This is the reason that your dishes are also not cleaned.
You might have to remove and check if the pump is faulty or a cleaning job can rectify the issue.
Sep 11, 2010 | KitchenAid KUDS03FTBL Dishwasher
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Apr 10, 2010 | Saniflo & Saniplus& Macerator Pump
During short spin cycles between rinses it doesn't pump water out
Try looking to see if the little motor is spinning the drain pump. It is in the bottom right. Occasionally I get a small metal shard which locks the pump and therefore-no draining. You can undo everything and check the pump for blockage. Then if need be, replace the mechanisim. The parts are all on line, as is the manual. or call 800 776-3538
May 11, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
350 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
