Question about LG Dishwashers
Keeps alarmimg 1E on my Lg Dishwasher
The dishwasher keeps alarming keeps 1E on Dishwasher and it stops into the cycle
  • Anonymous Mar 27, 2014
    keep getting the 1E Code
  • 725 Answers
Inlet water error 1E
Not reached to the normal water level in spite of 10 min. water supply
The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound.
Take action on Water Supply device. Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Posted on Sep 27, 2009
1E error code
Search Results
    E1 error on LG Dishwasher - YouTube
    ? 2:40
    www.youtube.com/watch?v=2qcwAyHI9ik
    Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Dishwasher Pump and Motor Assembly Replacement - LG ...
Sep 30, 2015 | Dishwashers
Cycle wont start washing, it flashes 1E on the screen.
( 1E) IT MEANS THAT U HAVE AN ERROR . CHEEK YOUR CYCLE WASHING SET UP
Mar 26, 2012 | LG LDF6810ST Stainless Steel Built-in...
I have the same problem !!!
I have the same thing happening to my dishwasher what do I do
Aug 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
Oct 08, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
(below 10 psi)
Inlet Valve is OK?
by impure water.
Solutions:
device.
by the Test Mode.
Aug 20, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LDF7811ST 1E code
Are you sure it's 1E and not LE error code??  The symptoms you mentioned indicates that it is an LE error code and the motor has an issue.  You will need to call a qualified LG technician to diagnose and resolve the problem.
Jun 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
670 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
