1991 Lincoln Mark VII Logo
Posted on Sep 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On borad computer acts eratic - 1991 Lincoln Mark VII
Anonymous
Level 3:
  • Master 1,111 Answers
  • Posted on Sep 24, 2009
Anonymous
Master
Level 3:
Answers
1111
Questions
Helped
453175
Points
3685
Most likely needs replacement moisture or other wires unhooked lack of maintenance may also contribute to the cause or even factory glitches are applicable rust wires rubbing cause this type of behavior or it may be a 02 sensor ...if a check engine is on a Midas or even an Auto Zone will give a computer diagnostics for free
1helpful
What could a no spark mean
A bad Coil , ignition control module , crankshaft position sensor ,no voltage to the ignition system ! No Start No Spark Cranks OK GMC Jimmy S10 Blazer
Eratic idiling
Could be fuel filter.
During the fuel process can not get more than 1-2 gal. at a time is it ventalation problem?
Some vehicle do have a filter at the end of the ventline and must be replaced.. aslo can cause fuel guage to act eratic as the tank vacums when driving.. can be the case if you travel dirt roads lots..
3helpful
Have 2001 GMC Yukon XL, and noticed fuel guage acting eratic and this afternoon car would not start at all...cannot hear fuel pump running
the fuel pump is inside the tank and i have seen trucks that the pump wiring harnes inside goes bad! when you turn the key on you should hear the pump running,if not i bet it is the wiring inside
1helpful
I have a 99 mazda B3000 2 wheel drive the abs light came on and the speedometer starting acting up where it won't work until I reach 40mph. is it the speed/abs sensor in the back axle
vice versa.. speedometer started acting up and caused the abs system to disenguage... eratic speedo replace the vss....vehicle speed sensor on transmission
1helpful
Check engine light flashing
you need to get transmission flushed..or check your transmission fluid. also get your injectors cleaned. the oxygen sensor is probably acting up.
1helpful
2answers
1986 Chevrolet Celebrity - Surging Eratic Acceleration
Sounds like you have a vacuum leak somewhere causing the engine to flood.Check all hoses coming fron intake manifold.
Starter does not engage.when key is turned gages are eratic?
check battery voltage it should be 12.5 volts.if all is good .you have a bad starter or starter solenoid switch.i
Misfire and eratic idle on Ford Focus petrol 1.8i
motor mounts need replacement and sounds like your cars comp. is about to take a hit and go down
the air flow control unit sounds like it also has has a clog in it and needs to be serviced this is a big one when you get to driving at higher speeds the fan turns off and the air outside controls cooling air/fuel mixture rate sometimes too much air intake can make the vehicle act eratic
Top Lincoln Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
