my internet connection turns off and on. I use modem then connect to router then the router connected to the switch hub but my problem is the connection turns off and on.
Sir,
First you need to know where it is disconnecting, when it
disconnects see if the panel on the router is indicating an Internet
connection... good? Or else check the
below steps:
go to start> run
type
cmd
type
flush /dns
try to reconnect
make sure window will configure your connection
log on to your router and assign your DNS address
If the problem is not solved, check with other user account
if it is worked or not? If not worked check with provider.
i have a Double NAT on My network and i need to turn off The NAT on my DIR-825 The other router is a...
(More)
i have a Double NAT on My network and i need to turn off The NAT on my DIR-825 The other router is a Verizon router an i do not have access to the settings.
