Question about Brother DCP 115C All-In-One InkJet Printer
Printer says it unable to clean 46 and I can't even shutdown printer it needs to be unplug to turn it off
  • riann_lacs Sep 24, 2009
    printer says it unable to clean 46 and I can't even shutdown printer it needs to be unplug to turn it off
    Problem Solver:
  • 10 Answers
Dear Sir/Madam,
If you are Still Getting the error message, the machine will need to be reset. Disconnect the machine from the power source for several minutes then reconnect it.
Also check for foreign objects, such as a clip or ripped paper, inside the machine. Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
Also try resetting the Printer. The procedure to reset the printer is given below.
  1. Presses the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
  2. Enter 8 & 0 by using the up arrow key & SET keys.
  3. Press the mono start key several times until the purge count appears on the LCD.
  4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
  5. Press the stop/exit key to return to the initial stage of the maintenance mode.
  6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode
Thanks
Good Luck
Posted on Sep 24, 2009
    Sergeant:
  • 191 Answers
Your printer is usb port suport divies ?
then printer powre aply coad to plug and on and of is currently mathed
the printer is use this time on and of is ok and computer is warking time in printer is of is ok and aply print then on printer is ok.
but computer is sutdown is ok but printer is not of this time and printer is second parts is on and of is warking time is ok.
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
Hi I have Brother dcp 350 printer. I have the error 46 unable to print/clean i cant get the printer back to normal functions. I have change the inks (all) and I am still get the same error message 46....
The messages unable to print, unable to clean, unable 36, error 46 and error 32 are all print head errors.
1. Remove all the ink cartridges from the machine
2. Clean the contacts on the cartridges as well as inside the machine itself with a small amount of warm water or alcohol on a cotton swab until no ink comes off on the swab.
Note: if any of the other cartridges are low, empty, leaking or bulging replace them
3. Then turn off the machine and unplug it for 70 seconds
4. Plug it back it and wait for the insert cartridges message
5. Insert the cartridges and check to see if the problem is still there. If it is it means the print head has failed and in order to fix this the print head inside the printer needs to be replaced. The print head is the part of the printer that puts ink from the cartridges onto the page
Unfortunately this can sometimes cost more to replace then the machine itself.
Apr 18, 2011 | Brother DCP-350C InkJet Printer
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Clean Unable 46
Clean unable 46 means that the ink tank is full. You need a replacement tank installed and the count reset. This is a holder inside for the used ink,best to be a shop repair.
Jun 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Unable to clean ... Brother MFC 3240C
Machine Error 46, Purged Ink Box Full
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An initial purge, for example, advances the purge counter by 187 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unusable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: unplug the unit, hold down the Menu/Set key, re-insert the power plug while holding down the Menu/Set key. The internal Machine Error Code will be displayed. Unplug and re-plug the unit again before continuing to the steps below.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the up arrow key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
May 27, 2008 | Brother MFC-3240C All-In-One InkJet...
Clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
Feb 09, 2008 | Brother DCP-340CW All-In-One InkJet...
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
159 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
