Question about Refrigerators
Bottom of Maytag Freezer Ices Up
I have a Maytag Plus Side by Side refrigerator and the bottom of the freezer keeps icing up to the point that I have to end up chipping out the ice on a monthly basis. It also ends up leaking on the kitchen floor. The fridge works fine and the rest of the freezer is no problem Maytag Model MSD2756AE has to have ice chipped out of bottom of freezer compartment every week. Also, even before the ice maker was hooked up, the refrigerator would leak water onto our kitchen floor intermittently, to the point where it would be dangerous if one walked into the kitchen at night and did not see the puddle. What gives?
  • Anonymous Mar 18, 2014
    1998 Maytag side by side. Leaking, ice build up bottom of freezer. Repair person was out, made sure hose was clear. Semed to be fine, bu is leaking again. Icemaker never been hooke up. Thank-you!
    ice maker
  • 410 Answers
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
Posted on Dec 16, 2007
I had this happen to me and I had to get Sears to come out and the coil was clogged with ice. It had to be thawed and that was it! It looked simple to do and I'm a girl! The repairman told me it may do that every 5 years or so. Just take the screws off the back. Chip away the ice. Rinse with water and wala! Be sure to turn it off first to keep the water from freezing, too.
Posted on Feb 22, 2009
  • Linda Varady Jun 04, 2013
    Will this work with the bottom freezer unit as well? I have the same problem but thought that the back of the refrigeraor was sealed and could not be opened. Your input would be great. I'm a girl too!!
I have condensate leakes into the bottom of my freezer and ices up the bottom of the freezer
YOUR DEFROST DRAIN IS CLOG UP YOU WILL NEED TO PULL THE BACK COVER OFF IN THE FREEZER SIDE AND CLEAN THE DRAIN YOU WILL SEE IT AT THE BOTTOM BEHIND THE FREEZER COVER
Oct 31, 2012 | Maytag Refrigerators
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Fridge Freezer ices up
easy....drain hole iced up....when it defrosts it will flood base of freezer....24 hour switched of to defrst it will cure it
Jul 15, 2009 | Refrigerators
Maytag refrigerator side stopped working; freezer is fine. WHY?
sounds like a defrost problem maytag has problems with the defrost thermostat use a hair dryer to melt the ice on the coils and see if the defrost thermostat is swelled up on the edge
Jun 30, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Warm Fridge
SOUNDS LIKE U MAY HAVE A BAD DEFROST TIMER, CAUSING THE COIL TO ICE UP, AN SINCE THE COIL ICES UP THERE IS NO AIR PASSING TRU TO KEEP THE FREEZER COLD AN THE FRIDGE COOLER, THE FAN MAY BE WORKING BUT IS NOT MOVING ANY AIRE TRU IT, BECAUSE THE BLOCKEAGE
May 28, 2009 | Maytag MB2262H Stainless Steel Bottom...
Samsung frost free fridge freezer ices bottom of freezer
it means that the freezer heater is bad, it's located after you remove the racks from the freezer and removing the back panel, it's at the bottom or below the condenser.
Dec 11, 2008 | Samsung RS2630WW Side by Side Refrigerator
Freezer ices up on bottom where the drain outlet is
clear it again and then go underneith and make the drain hose to shape like a j-trap and it will fix the problem ,,, if you have to, cut a piece of clothes hanger and slide it up the hose and then shape it / larry
Nov 29, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Zanussi 920/g R
your thermostat is faulty you will have to replace it if you keep doing what you are doing your gas will run out ok go to your local appliace shop and give them the model number and they should get you one cheap
Jan 06, 2008 | Zanussi ZEBF250W Bottom Freezer...
We had the same problem; soon your other side of the fridge will start to not cool as well. A circuit board had to be replaced per the Sears repair guy. Cost was about $270 but our icemaker doesn't work so well still. The ice cubes are hollow and it doesn't churn as well.
Aug 16, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
1,069 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
