Question about Jacuzzi RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,
The installation guide says that the heater unit needs to be bonded. there is the copper wire and the place to hook it up to the heater. but what dose bonding mean? Grounded?
The term "bonded" refers to properly grounding the heater. A 10-gage copper wire is needed between the heater and a metal water pope or grounding rod.
Posted on Jan 16, 2010
I have power to the balboa circuit board but not to the digital readout control/on-off temp. control box that connects to a telephone type connector. My unit is a outdoor hot tub mfged by Jacuzzi, My e mail is : frednrc@hotmail.com Thank you in advance for any help or comments.
Posted on Jun 26, 2010
mgw_4077: did you ever get an answer to your question about "bonding". I believe its basically running the cooper wire that jacuzzi provides and connecting it to in line heater and running it down to the ground screw on the electrical outlet. If that's not correct I would appreciate it if you could share your solution.
Posted on Dec 26, 2009
    President:
  • 2,976 Answers
I need more context of how they are using the word "bonded". It could be something as simple as grounded but, since it is a hot tub, I would rather have the full text where they mention it. They could also be talking about some special sort of insulation.
Posted on Sep 24, 2009
Trying to install a Woods 59018 with older copper wiring - My house only has one black wire (not the two black wires it calls for).
1) It is safe, but not code.
The timer uses such a tiny amount of power that the installation is safe, and the line is still protected by circuit breaker.
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
2) In the main breaker box, the neutral wires and ground wires are bonded together and both connect to ground wire leading out to pole and down into the ground.
3) By code a ground wire cannot be used as a neutral, even though both are connected together in the main box.
This is so electrician can work on ground wires while ASSUMING they do not complete a circuit.
NO ELECTRICIAN should assume that, since the purpose of ground wires is to ground stray current.
Dec 30, 2012 | Woods InWall 7 Day Digital Programmable...
Replaced a two speed with a one speed
A Better question is what is the voltage? 110 VAC or 220 VAC ... what were you running and what is the new pump. B W G would 'typically' be 110 VAC but could be 220. You must know the voltage you have and the voltage the motor is expecting before you hook anything up ... oh yes, one more wire - dont forget to bond the new motor to everything else, use #6 bare copper for the bond.
Nov 24, 2012 | Pool & Spa
How to ground a circuit breaker panel to an outside ground rod
First of all you need to have two grounding rods outside the house. Usually they're 12' long and have to be driven in 11-11.5 feet... but different particulars apply to different states and local codes. Ground rods should be placed no less than 6' away from each other and as closely placed as possible to the equipment or structure they are intended to protect.
wrap the stripped 14 AWG wire tightly around the copper ground rod. Try to get it as flush against the rod as if possible so that when you heat the rod later, it bonds very strongly at all points. Then heat the copper rod, rather than the wire and allow the wire to be heated by the rod. Don't heat wires directly or instant oxidation will occur, making it much more difficult to solder. Leave the ground rod to cool off for about an hour.
You would then dig the area to place the rods. The wires running off of them need to be ran to the circuit breaker box and terminated to the grounding bar. If there isn't a grounding bar in the box (only neutral) you can buy a single grounding bar specific to your box to install.
Jun 23, 2012 | Square D Qo 100 Amp Breaker Box Qo120m100...
PowerStar AE9.5 isn't working. Bought new. Water lines are hooked up to the correct water lines. The 240V wire coming from the breaker is hooked up as follows: Uncovered copper wire connected to ground,...
The unit will not owrk unless you have 240V ACROSS the black and white wires...if you do not have that coming to the unit then you have a bad breaker...
heatman101
Feb 19, 2011 | Bosch PowerStar AE9.5 AE9.5 Point-of-Use...
I need to convert a 3 prong dryer cord to a 4 prong
Hi. Ok, with the rear terminal block cover open, you will see three wires. Black on one end, white in the middle and red on the other end. Use your 3/8′ nut driver to remove the nuts or a Phillips screwdriver to remove the bolts (depending on your dryer) and remove each dryer cord wire from the terminal block. When you remove the nuts or bolts, be careful not to drop them down into your dryer. Next, you need to disconnect the bonding jumper on your dryer. The bonding jumper is either a metallic strap (typically copper or copper clad) or a green wire that is connected between your dryer’s neutral (white wire) terminal and the green ground screw connected to your dryer’s frame. If you removed a ground wire instead of a bonding strap from the neutral terminal, you need to connect this ground wire to your dryer’s frame. Loosen the screws at the connector and pull the cord out. Now thread your new cord through the connector and tighten down. This only needs to be snug do not over tighten. Sometimes the old connector will work with the new cord and sometimes not. If not, your new cord will include a connector that you may use. Now,to hook up your new 4-wire dryer cord, connect each wire to the dryer’s terminal block matching color for color (white to white, black to black and red to red). Connect the green wire to the green ground screw on your dryer’s frame. Once the wires are connected, simply recover the space, and secure the cove with the screw provided.
Aug 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Grounding wire# 8 cooper
The # 8 wire is a bonding wire for the hot tub or jacuzzi. It is to interconnect all the metal parts and equipment associated with the unit, pump, pipes, handrails, and also now there is a bushing that goes in the piping run to bond the water itself .
This wire will be incdentally connected to the electrical ground when it is bonded to the motor body.
Jun 10, 2010 | Jacuzzi RapidHeat Inline Heater S750
I have a 3 wire dryer and need to convertto a 4
The following link explains how to correctly install a 220VAC appliance cord:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Match the corresponding colors at the terminal block, making sure the Neutral (White) and Ground (Green or Bare Copper) wires are NOT terminated together.
If you have any questions, please post back and let me know. I hope this helps you.
Feb 03, 2010 | Kenmore 62602 Electric Dryer
How do I hook the wires up for a electric baseboard heater
this heater can usually be wired from either side. meaning your wiring can be brought through the wall inside of one side or the other.
the wiring you bring in to this unit needs to be 12g or larger.
it needs to be on a dedicated circuit. that means you cant splice into any other line. it needs to be for your baseboard heaters alone. that is code and wouldnt want to sleep in a house with baseboard heat that didnt have a dedicated circuit.
baseboard heat is most economical to run with 240v units. 120 is going to cost more to run.
you will need a thermostat either built into the unit or a thermostat unit mounted in the wall to run it.
dont mount the thermastat over the heater. I shouldnt have to explain why.
a 240 volt circuit run from your panel on a 20 amp breaker consists of 3 wires, a ground and a black and white.
in a 240v configuration both the black and white are hot and you must wrap some black tape around the white wire where it shows in your breaker panel and at the handy box in which you have installed the thermostat and then where it enters the heater. this re-designates the wire as a hot instaed of nuetral this gives you to black hots.
you hook the white and black wire to the line in side of the thermostat which should be the two red wires.then the two black load out wires of the thermastat run to your heater. hook your ground (green or bare) to the box if its metal and pig tail it to the ground screw on the thermastat, then out of that pigtail to the heater along with the two hot wires.
you will find a bare ground solid copper wire fixed to the inside connect your ground.
you will find two other wires they are both hots you will connect one of your hots to one of them and the other to the remaining.
what it looks like is an element sitting in the housing the housing is the baseboard and you have a hot wire running through a wire way to the other side and connecting to it and one hot stays on the side you brought the wires to.
in other words since you can wire it from either side you have to have a way to get the energy to one side or the other and they supply a way.
as long as this is labled as a 240 unit both wires are hot. take the covers off both ends you will notice the wire traveling from one side to the other. your goal is to have one hot connected at one end of the fillament and the other hot you brought in to the other end. the best way to hook up multiple heatrs is to have branch lines from the thermastat toeach heater, not to daisychain them one to the other becuase you will have voltage drop as a heater is using it before passing the voltage down the line leading to poorly functioning heaters
Mar 29, 2009 | Marley Electric Hydronic Baseboard Heater,...
Not sure hooked up correctly
The black and white wires should both go to the breaker. Not just the black wire. If you hook only the black wire to the breaker then you are only feeding the unit with 110 instead of 220. Both wires need to be hot.
Jan 20, 2009 | Fahrenheat Electric Convector Baseboard...
Hooking up my heater
The white is the common neutral, it is probably a 3 wire unit, and you are missing the ground wire. Check inside the control panel and see if someone wired it using the white wire for the ground, it will be screwed into a terminal lug. Check the schematics to see if the unit requires a common neutral to run the controls.
Nov 24, 2008 | Dayton G73 Utility Heater
Jacuzzi RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools, Logo
752 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
