Question about Microsoft Computers & Internet
Have 2001 quicken running on windows vista. when i try to print the check register, it says cannot open printer. i bought 2009 quicken and started to install, but it said it cannot save old register. it said to buy quicken that could save the old register. what do i do ,or buy???
    Problem Solver:
  • 10 Answers
Dear Sir/Madam,
To resolve this issue:
  1. From the Quicken File menu, choose Printer Setup, and then select the form that you are trying to print.
  2. Make sure that all selections and settings in the Printer Setup window are correct, especially the selection in the Printer drop-down list.
  3. If all information is correct, click Cancel and proceed to step 4. Otherwise, click OK after making the necessary corrections, and then try printing again.
  4. If the message persists, exit Quicken.
  5. Click the Microsoft® Windows® Start button, choose Settings, and then choose Printers.
  6. Right-click your printer and choose Properties.
  7. Click the Advanced tab, clear the Enable advanced printing features checkbox, and then click OK. Restart Quicken and try printing again.
  8. If the message persists, exit Quicken.
  9. Double-click Add Printer and proceed through the Add Printer wizard until you reach the window that asks for the printer manufacturer and model.
  10. Select the manufacturer for ex. HP, and then select the printer HP DeskJet 550C (or any other HP DeskJet 500 series printer). Follow the onscreen directions in the wizard to finish adding the printer.
  11. Restart Quicken. From the File menu, choose Printer Setup, and then select the form that you are trying to print.
  12. Select the printer you added in step 10 from the Printer drop-down list and then click OK.
Completely uninstall the old version and install the new version. Before install clear registry and temp files. Update the latest driver for printer.
Thanks
Good Luck
Posted on Sep 24, 2009
Printing check error code 7224
Using Quicken Premier 2009 on Windows 7 x64 with HP OfficeJet 7310.
My check wouldn't print and was booted out of Quicken. Validated data (was OK), reinstalled Quicken Premier 2009 (per instructions above), checked printer and driver (was-OK), I still could not print checks (error code 7215 and quicken closed).
SOLUTION: I deleted the transaction I was trying to print, the re-entered it. It printed fine.
Feb 13, 2010 | Intuit Quicken Premier 2009 for PC
I have Quicken 2009 and Windows Vista, HP Printer
I've tried off and on for a year to try to get assistance from Quicken and HP because my Quicken reports would not print. Everything else printed just fine. It was so frustrating because nothing worked. I needed to get reports to my accountant and thought I was just going to have to hand write the reports. In the end, I took a photo of the screen (with the report showing), downloaded the photo to the computer, tweeked it a bit with my photo software, then prrinted it. How goofy is this to get a report from a program that is supposed to make my life easier???!!!
Aug 19, 2009 | Computers & Internet
Quicken 2009 Deluxe will not print on Vista 64 system on HP 5610 All-in-one printer - ran all the usual suspects about drivers, rebooting, selecting right printer, etc. etc. no luck. Seems Quicken does...
Me too. None of my printers worked and each time I tried Quicken crashed. But only quicken had this problem. Then I read this super simple fix:
  • Click Edit from the menu bar, and choose Preferences > Quicken Program.
  • Go to Register > Notify, and remove the check mark from “Warn if a check number is re-used”
  • Click OK.
  • Print checks.
At this location: http://tinyurl.com/moehn3
Worked like a charm. Go figure. Wasn't even a duplicate check number.
Aug 18, 2009 | Computers & Internet
Cannot open printer from Quicken 2001 Deluxe
Check intiut's website. There have been some problems with 64-bit Windows Vista. You didn't specify whether you have 32-bit or 64-bit operating system.
Aug 09, 2009 | Intuit Quicken 2001 Deluxe (256101) for PC
Have Quicken 2008 and HP J6400 printer. Can print reports but can not print checks
Check that the problem is not caused by mismatched paper size, in that case you may need to correct printer settings and adjust also settings on Quicken.
Quicken 2008 is also known for having several bugs that affect printing, if you are considering an update to 2009, that should fix the problem.
You can also check if a patch to fix the problem is available contacting quicken online, check the links below:
Quicken® Personal Finance Software: Chat
Get Help with Quicken | Quicken Help and Support Options
Regards.
Jul 27, 2009 | Computers & Internet
Quicken Deluxe 2009 stopped working
your quicken deluxe 2009 is very OK... i think your system vista 64bit is the problem.. is there any other way that your 64bit vista is updating? if you try to use your quicken deluxe and it might works there.. so this time you are going to system restore your vista 64bit and back the recent checkpoint that quicken is run normally...
Jun 19, 2009 | Intuit Quicken Premier 2009 for PC
Printing check from Quicken 2009 Deluxe
All Printers have this issue printing from quicken you would need to download the older version of quicken from oldversion.com
Then uninstall the new version and install the old version.
all lexmark/canon/epson/brother/hp.....printers have this problem with the new quicken.
Or try calling in to us at 1800-474-6836 and provide us with a remote session with your computer we may be able to fix this issue with a basic driver.Let me know if you have connected the printer thru usb or ethernet and I will give you a resolution that works 70% of the time with the new quicken
Jun 16, 2009 | HP OfficeJet 6310 All-in-One Printer...
Basic Quicken on Windows Vista will not print to HP psc 2410
Symptoms:
This issue occurs after updating to Release (R6). Quicken is attempting to display a duplicate check number message, when the error occurs. We have identified this issue to be caused by one or more duplicate check numbers in the checking register.
Solution 1
  1. When clicking Print Checks, the next Check # to be printed is displayed. Take note of the check #, and then click Cancel.
  2. From the Checking register, click Find and search for the check number.
  3. Edit the transaction(s) to include the correct check number, or remove the check # from the transaction.
  4. Print checks.
Solution 2
  1. Click Edit from the menu bar, and choose Preferences > Quicken Program.
  2. Go to Register > Notify, and remove the check mark from “Warn if a check number is re-used”
  3. Click OK.
  4. Print checks.
May 01, 2009 | HP PSC 2410 All-In-One InkJet Printer
Quicken 2009 premier Installation
a bit fuzzy here in your statements
you have win xp installed and the quicken program runs there perfectly
is that correct ?
now on another pc you have win vista and quicken is not running there
is that correct?
or do you have both win xp and vista operating systems on the one laptop and are trying to get quicken to work on both on the one laptop
maybe the problem is that quicken version you have works well win win xp as it is compatible with that OS but is not compatible with win vista in which case you need to go to the quicken properties tab , click on compatibility tab and tick the box and high light window vista and apply the change or get a download upgrade vesion from quicken web site
Jul 18, 2017 | Computers & Internet
Computers & Internet Logo
155 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
