Question about Pentax Optio E30 Digital Camera
Can't view image, and "built in memory full" is displayed
    President:
  • 2,976 Answers
Connect your camera to a computer and offload all the pictures. Then, format the camera's internal memory. If you have a memory card, it's best to use that and only use the internal memory when the card fills up.
Posted on Sep 24, 2009
How can i transfer built in memory card to memory card if built in already full
Hi bacayemilita,
I think you meant that you need to transfer your images from your camera's built in storage to your external memory card.
Please follow the below steps :-
  1. Connect you camera to your computer via the USB cable and then switch your camera on.
  2. Once you switch the camera on you will find an option for mass storage mode , please select that option.
  3. Remember to remove the memory card from your camera while you do the above step.
  4. Once you select the mass storage mode , you will find a removable drive being displayed in my computer , in this drive you will find all your images, so all you need to do is copy them all to your hard disk drive.
  5. Now if you want to copy these images to your memory card , you can either do it via connecting your memory card to a card reader and copy the images from your hard disk onto it Or you can connect the camera while keeping the memory card in , and you will find another removable drive for memory card , when you select mass storage mode.
  6. When you find the drive , just simply copy the contents from your hard disk to your memory card's removable drive.
Hope this helps ..:) Your feed back would be greatly appreciated.
Jun 26, 2011 | Pentax Optio S4i Digital Camera
Camera built-in memory is full. How do i either download or delete items from internal memory? Nothing shows up when i try to view items stored in internal memory, but camera says it is full.
Hi walthonolulu,
If the camera's built in memory is full , then all you need to do , is connect your camera in Mass storage mode,
I would recommend you to remove the memory card for extra memory from your camera and then connect it to your PC in mass storage mode,
Then you would find a removable drive being displayed in my computer option and then you would have all your photos in it.
First copy these photos to your hard drive or your desktop and then you can select them all and delete them together.
Hope this helps ..:) Your feedback would be appreciated.
Jun 19, 2011 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
"Memory full" displays on screen.
You still need to get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format" and follow the on screen instructions to erase the internal memory. Then, insert your card and it should work properly.
Feb 12, 2011 | Nikon Coolpix L1 Digital Camera
How to save a picture to a memory stick,,
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Thanks for using FixYa
Dec 04, 2010 | Sony Cyber-shot DSC-T2 Digital Camera
How do i transfer my phone memory to the micro sd
You can store any multimedia files
on your phone’s memory in My stuff
so that you have easy access to all
of your pictures, sounds, videos and
games. You can also save your files to a
memory card. The advantage of using
a memory card is that you can free up
space on your phone’s memory.
My images
My images
contains a list of pictures
including default images pre-loaded
onto your phone, images downloaded
by you and images taken on your
phone’s camera.
My images options menu
The options available to you in My
images
depend on what type of
image you have selected. All of the
options will be available for pictures
you have taken on the phone’s
camera, but only the Use as, Sort
by Grid (List) view
and Memory
manager
options are available for
default images.
Send - Send the image to a friend.
Use as - Set the image to appear on
your phone at certain times.
Move - Move an image from the
phone memory to a memory card or
vice versa.
Copy - Copy an image from the phone
memory to a memory card or vice
versa.
Delete - Delete an image.
Mark/Unmark - Select multiple files.
Print - Print an image via PictBridge or
Bluetooth®.
File - Change the name or view the
information for the file.
Create new folder - Create a new
folder within the Pictures folder.
Slide show - Start a slide show.
Sort by - Sort images into a specified
order.
Grid view/ List view - View each
image in grid or list type.
Memory manager - View the memory
status.
Jul 26, 2009 | LG Secret ? KF750 Cellular Phone
Cant View Thumbnails on Camera
you can delete images from the 'stick' on computer- so long as you do not format on computer.
Mar 28, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Pentax Optio E30 Digital Camera Logo
97 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
