Question about Dell 926 All-In-One InkJet Printer
Scans stop at 99% and make the entire prog (all in one software)not responding as well as printer freezes between a double sides printing (after finishing the pages on one side)
    Sniper:
  • 51 Answers
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
You can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
good luck :)
http://tinyurl.com/yddyuw6
Posted on Oct 01, 2009
    Sergeant:
  • 191 Answers
Your pc in unstoller the printer and restart the computer and reinstoll the printer driver and printer select the printer and try a scan and prints.
Posted on Sep 24, 2009
How do I print double sided without scanning
You specify double sided from the print menu. For example from a Word file rather than just clicking the print icon; click file, print, select the appropriate printer, then properties. From there you can detail paper, paper source, 2-sided print, etc.
Oct 15, 2014 | Brother MFC-7440N All-In-One Laser Printer
Interact s605 printing upside down
You can change the settings under printing preferences, just follow the steps below:
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Navigate to:
Advanced tab > 2-Sided Printing area > select On
Note: To use the settings defined in the printer, select Use Printer Settings.
4 Select either the Side Flip or Top Flip option. Side Flip is the setting most often used.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
To return to single-sided printing, navigate to:
Advanced tab > 2-Sided Printing area > select Off
Sep 01, 2012 | Lexmark Interact S605 Wireless All-in-One...
I want to scan, but there is printing operation error. Ink has run out. And I can't scan because it says printer maintenance is in progress, scan later. Is it possible to cancel printer operation and...
Yes you can cancel the maintenance process of your printer..just do this steps 1. Click the start menu on the left side of the taskbar then click control panel 2. On the control panel click devices and printers 3.double click your printer icon 4. on the printer window right click the documents you want to be stop printing the chose cancel print.. after doing these steps you can start now scanning. that's all! hope it will help you
Jul 12, 2011 | Canon PIXMA MP160 All-In-One Printer
Hi Sir! We have in the school a IR2020. It work good. 1. How can I set the double site printing from computer? 2. How can I scanning. thx.
Double side printing is possible if you have duplex unit insstalled.Do you have duplex unit?
Under printer properties there must be page setup, where you say that you want to print double sided.
You can scan over ScanGear software. Do you have it? If not you can download it from canon official site.
But it works only as PULL scanner.
Jun 09, 2010 | Canon iR 2020i Laser Printer
Printer does not respond to print button for test
REmove and renstall the drivers. Do this through the Printer folder. Delete the printer, unplug it, reboot. If you have the software, use it. If you need the software, get it via download from the manufacturer. Follow the manufacturers instructions as they appear on the screen.
Feb 25, 2010 | Zebra P640i Thermal Printer
How do i print double sided?
No unless your printer has an add-on or built-in mechanism that allows for double sided printing,
Feb 18, 2010 | Computers & Internet
The resume and power buttons are flashing on my 5550 deskjet; nothing works. The print queue is empty and there are no outstanding (manual) double-sided pages waiting. Temporarily disconnecting the ...
Here is a page explaining how to resolve this issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=71895&prodTypeId=18972&prodSeriesId=71895&objectID=c00681585
Nov 12, 2009 | HP DeskJet 5550 InkJet Printer
My c3180 can print but canot scan, i dont have disc and my win is vista
Try This :
Uninstall the entire software from "Programs and features" in control panel of your computer.
Double Click on each HP software related to your printer and Uninstall it.
Download the software from the Below Given Link :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1146331&lc=en&cc=us&dlc=en&lang=en&cc=us
Select your Operating System
Click on download
Save it to your Desktop
Run the software
Install it through Recommended Option
Then after the installation completes you will find and Icon HP solution center
try scanning from there it should work
Otherwise let me know
Regards Soumajit
Sep 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP PSC 1510 All-In-One-Printer not responding
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
Double sided printing Pixma MP520
here's how:
print double sided pages
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Sep 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Dell 926 All-In-One InkJet Printer Logo
117 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
